hows your board doing now Angelo ? I still have the same 5600 OC with the 1502 bios...was it an inferior mount ?
@pacha: maybe u pump too much V into for "only" 4,6ghz. At SB less is more ;)
I had BSOD just after boot at 4.6 1.3V so I crancked up the vcore directly to 1.35V, maybe 1.325 would have been enough, I'm too much used to crank the vcore or vgpu +0.3V from stock as a limit lol, that's not really needed here.
Anyway, I'm at 4.6G 1.35V right now with the changes I made, and no BSOD so far, I'll see within 24h if it crashes or not, otherwise I'll try with 1.325V or something.
Apparently, it doesn't get low like that as I don't use turbo nor EIST, CPU-Z shows 1.35V ±0.02V through time, be it 0% or 100% load on the cpu. It's note like I was idling at 1.6G and there was too much vdroop.
if u have another crash pls post the BSOD Code
I will. Thanks.
For what it is worth, my board shuts down instantly 2 or 3 times while browsing the internet when I get home from work. After a couple complete shut downs it starts up and runs 100% no matter what I do, game, bench or stability test.
I thought it was a fluke or power issue at the wall but it does it EVERY day for the last month or so. Same exact thing every day, very odd.
RAM is already at stock settings. No BSOD so far, so I guess the BIOS parameters made it. I'll focus on oc the RAM if it remains stable one or two days more.
Hi, i just bought ASUS P8P67 pro bios 1204 and trying to pas @i5 2500K > 5.4GHz Vcore 1.54v
i ve a problem after boot up message like this :
CPU over voltage error!
press F1 to continue.
if press F1 go to bios, i checked Vcore can't more than 1.53v
any idea's dude?thx alot for helping me, i appreciate that
got somebody impressions with the 1502 bios against the 1204 ?
hah BSOD again... took a while before happening this time but it happened.
I'm back to 2T on the RAM to see how it goes, and lowered vcore to 1.34 instead of 1.35V. I'm still LinX stable, I guess it should even do it with less V. I'll see if it :banana::banana::banana::banana:s again, otherwise I'll put LLC on High or Ultra High et see.
BSOD Code as mentioned ?
I totally forgot that one. I have no log in bluescreenview, though the BSOD is dumping memory to disk each time.
Nevermind, I installed WinDbg as I did on XP before. Here's what the dump says :
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000002088, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800028a9edd, address which referenced memory
Debugging Details:
READ_ADDRESS: 0000000000002088
CURRENT_IRQL: 0
FAULTING_IP:
nt!KiProcessExpiredTimerList+9d
028a9edd 49 dec ecx
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
LAST_CONTROL_TRANSFER: from 0000000000000000 to 0000000000000000
STACK_TEXT:
00000000 00000000 00000000 00000000 00000000 0x0
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
028a9edd 49 dec ecx
SYMBOL_NAME: nt!KiProcessExpiredTimerList+9d
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: INVALID_KERNEL_CONTEXT
MODULE_NAME: Unknown_Module
Followup: MachineOwner
That may sound idiot, but with all my previous rigs I always had enough stability with 30mins prime for any office and gaming use (though it's been a few years I've not played a game), hence I don't get why LinX stable would mean idle or very light load applications to lead to BSOD.
I'm not folding nor using any app of the sort loading the 4 cores all the way for many hours, so I don't see any reason to have 8 hours prime stability like some do here.
@pacha: how many v do u use @Vccio ?
Auto for VCCIO and all other voltages except vcore and vdimm
I'm back with another BSOD so 1.34V doesn't seem to do just fine, and problem doesn't come from 1T/2T on the RAM.
I've just set LLC on ultra high. I'll see, but knowing that with Extreme LLC it crashed also...
I don't get it. Or there's not enough vcore and as it's unstable sometimes it dips too low even in idle when I'm at 4.6G all the time. I don't know.
Or this has to do with VCCIO not high enough or something maybe, but it's just very logical seeing the asus guide and guys values round here.
Bump VCCIO to 1.1 and try SA also ;)
