I have varied the VCORE anywhere from 1.1 to 1.2375 to no avail. I have also disabled LLC. Once again there was no difference. Per suggestions, northbridge voltage was changed to 1.35 which yielded no difference.
The AS5 was applied to the XIGMATEK in the manner that is described here:
http://benchmarkreviews.com/index.ph...1&limitstart=5
[Scroll down to the last two pictures]
A single line of AS5 was also applied to the middle of the CPU as suggested by AS.
This method of applying AS5 to the Xigie and the CPU was tried by a few members of the HardForum. These folks experienced quite a bit of drop in temperatures.
Currently all BIOS settings with the exception of VCORE, C1E Support, DRAM Frequency and DRAM Voltage are set to Auto or default values.
