Jcool, if we BSEL mod our chip to 1600 instead of 1333 wouldnt that change our Ratio from 1:1 to 5:4? resulting in a bigger window to overclock..
Hi s0lid! How are you today?
Thanks to you all for your ansvers. I think I will go for the XSPC RS360 rad. I'm a bit worried that will the pump make enough flow for the loop. Martins flowrate calculator estimates poor flow for it. We shall see.
Now the EK-Supremes fits nicely on the Z7S but not so beautifully as milkmandan's EK's ;)
Deagol, I'm fine :D
Could you post us some pictures (hw pr0n :ROTF:)
Btw if u use irc join to our irc channel which is xs.wcg @ Quakenet
Agreed..
And don't worry about the flowrate too much, the EK Supreme performs remarkably well even at very low flow rates, one laing will do the job more than well (I got a gigantic loop with 2x EK Supreme, 2 Rads, Raidcon and HDDs with one Eheim-based pump :D :rolleyes: )
As long as its 70 under load thats ok. If its going higher under load then you can use an application to control the GPU target temperature.
just did a log of it with HDMonitor PRO, while playing COD World at War, it got to 91c.. thats a little hot for my liking, the other one only got to about 55C.. about to order 2 Koolance water Blocks.. i just dont know if my 2 radiators will be enough..
Edit: just got another Radiator, Reservoir and GPU blocks.. ill use the same pump , but the GPU will have its own radiator to dissipate the GPU's heat
I Just disassembled Kandalfs own loop. And for my wonder what do I find... It seems that there is algy in the system. I don't wonder no more why people are saying so bad things about TT. :D
Here is two picls of the stuff
Didnt put UV reactive dye in the water did you? People often put way too much in and it looks a lot like algea.
Just an FYI guys,
my Z7S is dead I'm afraid.. was testing a certain burnt mem and I guess it fried the mem VRM.. jumps straight to FF when powered on and you can hear strange alternating squealing noises coming from the coils around the mem sockets :(
Oh well... gonna buy a new one, RMAing this thing is gonna take ages I bet. Guess I'll have an RMAed mobo on sale in a few weeks ;)
That damaged memory stick killed your board ? that sucks :shakes:
I'm moving to Nehalem soon. The E5420's are on e-bay , the SM board goes to s0lid . The Asus Z7S stays here for a while though :)
Yeah, it worked fine in another Z7S so I thought I'd give it a try... bad idea.
I'm just glad I didn't send it to you :rolleyes:
jcool sorry to hear, but you are not alone. I was building my machine and couple hours ago I noticed that my second EK-supreme was missing the thumbnut's. I hope the board is not too bended from my rough hands. I did some McGyvering to get those EK's on the mobo ;). Also my order was delayd and the shop says they will get the Laing pump on friday, so it will be shipped on monday. I hope this P500 can do the job until that time. (not as bad as your prob. thou)
I'm about to test the loop in few minutes from now. Why the heck do I loan my stuff to my friends? Always when you need some thing it's not there. How the hell I'm going to power the pump now! Well Maybe I'll use this comp to do it.
Has any one got 4gb memory sticks in his Z7S? And if yes are those performing well?
jcool, what are you voltage settings to hit 4.06ghz, i am stuck at 3.7 on stock voltage, and i have nearly the same stuff as you..
Erm... I think 1,3125V set in bios, which equaled 1,23-1,24V Vcore loaded in prime95. The Z7S undervolts by almost 0,05V from stock, so you have to increase Vcore quite a bit to get the "real" stock Vcore. I was still running below stock VID (which is 1,250V for any X series Xeons).
I'm getting the Z7S WS tomorrow :D
I hope that the stock bios recognizes my CPU's ( Q5XQ ES) so i can upgrade the bios.
Good XEON coolers are realy hard to find here so i ordered 2 Thermalright HR-01 X coolers and hope they will do.
good luck, that cpu is not on there comp. list
http://support.asus.com/cpusupport/c...model=Z7S%20WS
hopefully the 401 bios will recognize it..
It should be with the latest bios
http://www.cpu-world.com/sspec/Q5/Q5XQ.html
It's a X5460 and that one is listed on the Asus site
Xeon(X5460) 3.16 GHz(1333 MHz FSB/12MB L2,C0) (supported with the latest bios)
When it won't boot due the old bios i have to grab the cpu's from my server to update the bios :eek:
If it's a C0, no worries. They work perfectly fine with any bios. Only issues with pre-0401 bioses and E0 CPUs...
Doesn't have any trouble with odd CPUs either, my E5440 ES (B1 step!) ran just fine...
jcool, how many points can you average with your rig on WGC
