Looks good, though you used a lot of soldering tin. Not bad at all for a first-timer, though,, you'll get better :).
Soldering to ground points is always a bit harder than soldering to resistors. Did you have any problem soldering the wire to the trimmer? If not, your soldering iron is more than okay.
