F5c now out for DQ6....
http://www.jzelectronic.de/jz2/index.php
Has any1 tried f5c for DQ6? Is there any improvement for stability? i know only this:
1. Warning VDimm > +0.275V
2. Fix Diverse
THX!
Respect!
surely CPU Thermal Monitor gave you a clue? :p:Quote:
Originally Posted by GAM
this option does not affect idle speeds, it throttles the cpu once it reaches a preset temperature to prevent damage occuring to the die
@ BottomsUp, DS3 F6A BIOS : http://www.xtremesystems.org/forums/...d.php?t=115157
Doh, :slapass:. Sorry, was thinking of CPU EIST Function.Quote:
Originally Posted by Pyr0
(note, deleted erroneous post)
FYI (Extract from planetx64 http://www.planetx64.com/index.php?o...limitstart=3):
CPU Enhanced Halt (C1E) will slow down your CPU when idle to keep temperatures down, this is like the Cool ānā Quiet feature of the AMD processors, and for maximum performance when benchmarking it is recommended to set it to disabled.
CPU Thermal Monitor 2 (TM2) will throttle your CPU when it reaches a preset temperature.
CPU EIST Function enables/disables the Enhanced Intel SpeedStep Technology which is a lot bit like the AMD Cool'n'Quiet feature. If enabled, EIST will throttle your CPU speed (Via the multipliers) and Voltage when the processor is idle.
Virtualization Technology is an option for future use, currently no software takes advantage of it. Possible support may be introduced in future versions of applications such as VMware or it may be useful in Vista, but for the time being, I set it to disabled.
I have tried you various bios on my DS4, F3 F4C F4 and the last F5B but with the C1E seems strange like if it didn't work... all to default and all enabled but from cpu-z it always remains firm to max...it never doesn't come down neither in idle
what can be? :stick: :confused:
I haven't played with them much but try the CPU EIST Function. With this enabled I would regularly notice the multiplier dropping from 8x to 6x in idle moments.
all enabled....Not-Execute, C1E, Thermal Monitor ad EIST....infact is that would to happen but with any bios doesn't change, remains firm to the maximum :confused:
in the windows control panel > power options, have you tried changing the power schemes?
in win i don't change nothing :confused: .....with other P4 which supported the function C1E wasn't necessary to change something and it went normal....however I try thanks ;)
Mirror all DS3 bios incl F6a http://www.cranox.com/Gigabyte/DS3/
Woah cranox, who's that chick :D
Ok, I've got a DQ6 and F4 loaded, but I'm utterly confused as to setting the fsb:memory divider. All I can see (even after ctrl+f1) is the System Memory Multiplier, which is simply fsb * mult = Memory MHz...this is *not* what I'm after.
What if I want to force my RAM to say 2/3rd FSB, or 5/6 FSB?
Cheers!
Also any advantages of moving to F5c?
Does anyone know if my RAID5 array will be destroyed if I update my BIOS?
Originally Posted by celerity
ahhhh...no
anyone try F6a? yet
I must say im on the verge :mad:, so close to taking a screwdriver and killing my DS4, even at 400fsb witch is 7 hours prime stable i still cant reboot, have to reset 27 times to get back from perpetual onoffonoff bla bla...:slapass:
F5B bios just makes it worse and even my "stable" settings didnt work, and the bios wouldent even save this, just bootet stock all the time..
To heck with the colours, get the oc settings to work properly Gigabyte!!
Im went back to F4 final, and then i tried 430fsb, 1,45Vc, Vmch +0,45, +550 Vdimm, pci-e 100mhz, and wow it bootet into win but after 5 mins it crashed, i try'd loads of different settings after this but it wouldent boot at 430fsb again...
What to do now?
I have exactly the same problem as you have. I have just tried the F3 yet but finaly I got it to Boot at 8x400 with vCore 1,465 Dimm +0,4 Vmch +0,15 and FSB +0,15 and it was stable with PI M32 no problem. Made several reboots still no problem, turned it on after a trip to town and then it just boots 2sec and then of and on like that for ever and i have to CMOS and start all over again. This must be some kind of bios issue, kind of sad to hear thet the problems aint solved with the newer bioses :slapass:Quote:
Originally Posted by GrindBastard
Still on stock cooling though. Do you have thge same kind of problems to get above 400 with water on CPU and NB??
when the mobo enter in cycle on-off-on-off just pull out battery ;)Quote:
regards
Well im searching for some answers to, maybe its a stripe issue and all fsb settings from 401 and on is no go...Quote:
Originally Posted by Dirt
I have tried multiple settings, all settings in advanced bios settings are disabled, from no execute to virtualization, and i left the side of my stacker case for 2 weeks, i can reset the cmos in a jif now... :mad:
All my temps are fine, chipset is not watercooled, but i have 2*80mm fans over mems and chipset, so its not a heat problem..
I reset it at the front of my stacker, if i have to pull the battery out i need to take my gfx and radiator out...Quote:
Originally Posted by mascaras
Its a damn nightmare.. :slapass:
So if I pull the battery it wount reset the settings to default?? Thats the anoying part that you have to enter all the :banana::banana::banana::banana: into the bios again :mad: Must say that this board start to piss me off.Quote:
DS3 has best BIOS support until now and DS4 has worst BIOS support until now
I did not notice any difference from F4e, though I have not had much time to tinker.Quote:
Originally Posted by Ajfina
http://www.xtremesystems.org/forums/...=1#post1710794
noooooo you dont have to yank the batter all you have to do is reset the cmos.
guys listen..
99.9% of the rebooting issue caused by these baords is caused by two things.
not enough vcore or too tight of timings on the ram.
you also need to start nailing the insert and delete keys when it goes into the reboot sequence.
this will force it back to defualts to get you into the bios.
its supposed to only be the insert key but it doesnt always work many times i have to do it 5 or 6 times ot get it to work but its easier then opening the case and going in and resetting the cmos.. lol sometimes.
yes it will reset everything
but there isnt that much in the bios it shouldnt take you more than 1 minute to go thru and redo all the bios stuff. its not the end of the world.
but yes gigabyte needs to get off their collective a$$es and fix this sh|t.
the board needs to reset itself to a safe boot mode so you can get back into the bios.
I wish you had mentioned this before now :rolleyes:Quote:
Originally Posted by Lestat
