not sure if you guys have seen this post at EOC yet, or if there is a monarch rep that posted it here somewhere
http://forums.extremeoverclocking.co...d.php?t=220707
I didn't even know there was a coupon :(Quote:
Originally Posted by tvdang7
Thanks to itznfb for pointing me in this direction.
Model: 165
Stepping: CCB1E
Date: 0609
Package Code: FPMW
CPU Frequency: 3006
VCore: 1.55v
Cooling: Watercooling
Load Temperature: 43*C
Prime Stability: ~16 hours Prime stable
The MeatFrog but your Wafercharge is different.
The best DPMW have 1434904C60XXX
And yours is 143483AC60XXX!!!!! Could be worser than the others!
Got my opteron 170 up and running finaly. Im mad. Its a CCBWE 0609FPAW.
It on a crappy At8 32x( crappy because it cant run past 257 without some crazy mem dividers.)
I build a 0550umpw for a friend. Hopeing to get the same 2.7GHz on stock volts. But I Can even come close.
Fails under dual pi. Can do one pi, fold, and bench all day long though.
Click for full pic.
pic deleted broken link
There are 2 wafercharges?!? Now I'll take off my cooling to see mine. You got a link to a forum with these results? Also, a little OT, but what did you use for your 170, AS5, or ceramique?Quote:
Originally Posted by Rufus7
Monarch Computer has the AMD opteron 165 Dual Core Processor OEM $337.67 - $67 off Coupon code: 41106-120339 = $270.67, $5 shipping. Search for 120339
Monarch Computer has the AMD opteron 165 Dual Core Processor OEM $337.67 - $67 off Coupon code: 41106-120339 = $270.67, $5 shipping. Search for 120339Quote:
Originally Posted by TheMeatFrog
wow. 2.5 @ 1.7v??!! thats insane.Quote:
Originally Posted by sokarul
Its a glich, its stock volts.
an old CPU id like to add to the database as well
Model: 170
Stepping: CCBWE
Date: 0546
Package Code: XPMW
CPU Frequency: 2700
VCore: 1.5v
Cooling: TT Big Typhoon
Load Temperature: ~50C
Prime Stability: 8+ hours stable
Rufus, my wafercharge is 1434904C60XXX (batch number in the 700s). Do you have a link with other results?Quote:
I have seen one with that Wafercharge.
But the X2 3800 060BPMW are also not bad going around 3 Gig.
One iss known in Germany. But they are Tray and Toledos desactivated Half Cache.
Nice wallpaper, got the file;) ?Quote:
Originally Posted by 865pe
Yeap i just saw one myself, an 0608BPMW CCB1E stepping 3800+. Toledo with disabled cache, should run hot and overclock high.Quote:
Hi,
I got two CCBBE s 0610 -one is batch 099 and the other 368
099 is capable of 3GHZ at 1,5 VCore, the 368 seems even a bit better :)
3GHz at 1.44VCore. Try 3DM06 loop for gaming stability , guys, not just Prime.
http://img208.imageshack.us/img208/7...144v1ii.th.jpg
Now I am going to try some games and do some more benchmarking .
But 3DM 06 loop will show me, if it s capable of gaming :D
test not runnig :stick: please show cpu usage..Quote:
Originally Posted by famich
I'm running rosetta now on my 165 3.1ghz@1.500v. Ran all night and didn't give up, so I guess it's stable :)
Nice Repoman with your 0608MPMW?
Thanks man ;)
Yep 0608mpmw. Running 33-35C load with 1.5v now :woot:
Wonderful Chip.
Is the 170 CCB1E 0550VPMW 0550 VPMW worth $500+? Just received a second chance offer from an ebayer. Or should I take a chance on one of these 165's. I need to grab one more of these dual core chips that clock well & I'd like one that will do 3 Ghz without extreme voltage. I'm happy with my 2.8 @1.4vcore but I really would like 3 GHZ+ when I go to Quakecon this year.
Anyone willing to post CCBBE 0615 EPMW results yet? even if they are still in progress, i´m v interested of knowing what it can do.
Dude, stop that test right now. Don't you see PAGING in RED? That means it's not testing your cpu, and instead, thrashing your hard drives. If you don't want to kill them, I suggest you stop it right now. Next time, use 400/400MB for each test, since you're running 1GB. Chances are you will have to bump the vcore up a notch to gain stability.Quote:
Originally Posted by thunderstruck!
really? mine does that too. should we just do cpu test instead?
Little update on my 0610DPMW. I really miss the 10x multi, so you might see it for sale this week.:shrug:
http://img198.imageshack.us/img198/2356/17qg.th.jpg
