But does it boot at 2400mhz Gaul ? Don't think so... so that ram divider is useless for normal SB...
2 questions :
1) I wanna see a video now where your rig boots with the 2400mhz divider...
2) why do you start talking about 1200mhz ?
We bench at 2250mhz CL7-8-7, wtf is 1200Mhz CL7 ?
LOL i'd love to see you get that divider working with your setup ;)
Asus removed 2400 divider in latest BIOS's for all boards.
http://hardforum.com/showpost.php?p=...postcount=4278
it worked with some early ES samples mate, doesn't work with current retails... it just doesn't post... We've got rams that could handle them frequencies ( with loose timings) it just doesn't post...
So I tried the bios today, multi step is there.. which level is probably the best to use?
I just need 1.380V at max load and no less than 1.000v at idle.. level4? or just turn off multi step and enabled standard LLC?
F6h is out.
link & what's new stasio...thanks
In my sig.
tryed
ok back to llc disabled and enabled.
more stable and great performance.
no levels or what ???
sorry can't post anything coz had ASUS board now
^^ then stay off this thread.
Definitely one of the most worthless comments in this thread...awesome job!
I just downloaded the new BIOS and will give it a try tomorrow morning. I don't see how it can be much more stable than F6F but if it gets me my final 100MHz then I'll be happy. I don't use the mult-level LLC options so they won't be missed by me. I'll post my results up once I get some time to play with it.
Question for you guys. I have the UD5 board but that thread has been stone cold dead for a while so I will ask here. I used to run 5.0 rock stable with my old NON B3 board. Once I received my B3 board I could no longer get 5.0 stable. Anybody else run into this issue or is my 2600K degrading?
Also what is with everybody switching to the Z68 boards? From my understanding the only thing over the P67 it offers is the use of the on chip gpu to do either video out or rendering. So I cant figure out what I am missing out on by not getting a Z68 board? Must be some reason everybody is switching to the Z68?
F6i is out.
6 core ivy maybe, now i really wonder ....
http://www.pohrani.com/?8/2L/4qkWhz64/6core1155.jpg
http://www.pohrani.com/f/8/2L/4qkWhz64/1/6core1155.jpg
F5 officialy supports 22nm ivy bridge
F6i is special Beta BIOS for GB Germany,they adjust some voltages,as per they request.
F6F the american overclocker standar ...why more?
F6 is out.
