This is what I have so far ......
Attachment 85650
Just running the same but at CR1. I noticed that when I quit prime CPUZ was reporting a 455FSB which settled back down to 450FSB after about 30 seconds.
Bios settings are as follows - the numbers in brackets are for 430FSB :-
Extreme Tweaker Menu
Ai Overclock Tuner: Manual
OC from CPU level up: Auto
FSB frequency - 450 (430)
CPU ratio setting: 9
CPU configuration: default
-cpu clock skew - Normal
-nb clock skew - Normal
FSB Strap to North Bridge - 333
PCI frequency - 100
DRAM FREQUENCY - 1801 (1721)
DRAM Command Rate - 2T (running 1T now)
DRAM Timing Control - Manual
*1st information : 7-7-7-18-5-88-12-6
*2nd information : 8-6-6-4-7-4-7
*3rd information : 23-8-1-8-8
DRAM Static Read Control - Disable
DRAM Dynamic Write Control - Disable
-DRAM Skew Control
Ai Clock Twister - Auto
Ai Transaction Booster - Auto
*C/P : A1 A2 | B1 B2
*LVL : 06 06 | 06 06
EPU II Phase Control - Auto
*** Please Key in Numbers or select voltage!***
CPU Voltage - 1.45
Load-Line Calibration - Disable
CPU PLL Voltage - 1.656 (1.617)
FSB Termination Voltage - 1.457 (1.418)
CPU GTLVref (o) - +40
CPU GTLVref (1) - +50
CPU GTLVref (2) - +50
CPU GTLVref (3) - +40
NB GTLVref - +30
North Bridge Voltage - 1.550 (1.510)
DRAM Voltage - 2.014
NB DDRVref - Auto
DDR3 ChannelA Vref - Auto
DDR3 ChannelB Vref - Auto
South Bridge 1.5 Voltage - 1.603
South Bridge 1.05 Voltage - 1.086
CPU Spread Spectrum - Diable
PCIE Spread Spectrum - Disable
This is all on air with AS5 and washer mod to heatpipe assembly. Other than the temps I am happy with the 450 setup :up:
