Originally Posted by TinTin
That's my retailed MB, not a sample MB... ;)
If you are going to test higher HTT with a newcastle core A64, you will be disappointed, most got around 3xxMHz HTT, finished, but with a clawhammer, it is easy to get over 400HTT, though higher HTT with async. low freq. of RAM got almost no advantages.
If you only got 250HTT, there should be somethings wrong in the settings, apart from lowering the RAM freq. and CPU multiplier, try to set the LDT ratio (LDT/FSB frequency ratio) to AUTO, it is the best setting when you are playing high HTT, you may get boot problem if you set the ratio manually, e.g. 2X, 2.5X.......bugs.
You can then check by sandra to see what the actual ratio the BIOS has set for you...e.g. for 425HTT, the MB has set a ratio 2.5X for you (see attachment), i.e. 1062.5MHz Hypertransport!
