What do you mean by "not working"? Any error messages, etc.? If so, screenshot please.
Are you running the program with admin privileges? If not, please do so.
using v2.1, standard stress level with threads set to auto it will successfully complete any amount of runs I set it too. If I switch stress level to maximum and leave threads to auto (Haven't tried any other) I hit start and then immediately after it says it completed successfully, no matter how many runs I have it set to.
i've got the same problem with my e8400, i cant run the 2.1v but the other versions works well.
http://img29.imageshack.us/img29/7236/70514354.th.jpg
How many threads shall i set it too on my QX9650? 4?
Also how much does this test the stability of my RAM?? Is it still best to memtest or prime to check the memory?
Thanks great tool :)
Thanks agentGOD
I have installed Vista 64 on another partition so am using IBT with that rather than XP
By using Vista..would that highlight any RAM issues better than XP. Would you recommend still using memtest with RAM stability even while testing with vista or if I can get 10 clear passes in Vista I should be ok??
Does Linpack work properly on Win7?
can you update the original post about the i7 needing 16 threads to give a true result please :)
not that i didnt enjoy reading the thread, but it will help the average jo bloggs.
great little package you put together :D
Hmmm my pc shut down 15 seconds in. Temps were only around 65c.
Updated IntelBurnTest to v2.2!
- Now outputs result of test (success, failure, etc) in log
- Now outputs stress level tested in log
- Added "high", and "very high" stress levels
- Fixed a small bug that could've broken logging
- Added debug logging for troubleshooting (right-click logging checkbox)
As said in the readme, if you have any issues, please help me find the cause by enabling the debug logger (added in v2.2), and then sending me the log file, as well as a screenshot of the issue.
Thanks to all for your support!
Nice AgentGOD! keep up the good work!:up:
I can't run the program, it gives me this msg:
http://img268.imageshack.us/img268/3566/ibt.jpg
the fire thingy that animates ( freeze test) sometimes stops moving if you open a window and drag it on top so it covers the flame. To get it moving again I have to drag the IBT window "off screen" and then back on. Seems to just be a visual bug, the benching never gets affected, but since it looks like a freeze, not sure if this can be fixed. I have an nvidia 9600gt video card, latest drivers as of 6-20-09 and running vista x64 sp2 not sure if any of that matters.......
