640 PL9:D Very good.
Watch out guys, here is what I found when checking the NB/SB contact on a new board...:mad:
I had to heat the NB Rad a lot because it was impossible to remove it. Paste is hard as stone when cold...
http://pix.nofrag.com/c/2/5/8ed288be...4ea91c256t.jpg
Once cleaned, i found these references: http://pix.nofrag.com/2/2/7/d4cb0162...82c5920att.jpg
Did some of you checked that detail? It could certainly be interesting to compare them Premiums with this.
Which detail do you mean?
This is my one, cleaned from that crazy stuff a few minutes ago.. :p:
http://img524.imageshack.us/img524/2522/imgp5456uo0.jpg
My Chipset is close to one year old! :eek:
Mine should be older than yours ? Am i correct ?
Sorry, can't see anything on your picture. ;)
here you go:
NU82X48
SLASF
L747B177
INTEL "M" "C" '07
Thank you bro
This mobo isn't tested yet, The one I did my results with, Idon't know yet. Must remove the cooling... This one is a brand new one :D
I love them Premium boards
Board works great with the new E0 quads. Not compareable to my MSI P54D3..
http://img219.imageshack.us/img219/5541/vantagedc2.jpg
http://img527.imageshack.us/img527/2...0mhzht3.th.jpg
http://valid.x86-secret.com/show_oc.php?id=424213
657*6 PL9 :)
657*6 PL9 :)
Nice :up:
And about a Super Pi 32mo, at which maximal fsb do you make it ?
Keep pushing:)
If you have the board too, you can look at my settings best with oc-profile: http://www.gravedigga.de/gravedigga/...ile/ALLDAY.CMO
http://img81.imageshack.us/img81/923...202vug4.th.jpghttp://img81.imageshack.us/images/thpix.gif
Great memory oc on this mainboard! Close to my 790i. :up:
Edit: It was some handpicked Mushkin PC14400, other kit are Cellshocks.
I fyou can choose up too 2.25V in bios, i think it will be fine! :D And my nb is cooled with water. It is really cold.
This morning's test, I'm searching for good settings on this new 0605 BIOS:
http://images4.hiboox.com/images/400...502ae0e69a.jpg
http://images4.hiboox.com/images/400...cf6377d1a6.jpg
what?! A new BIOS?
noticed any changes (read: improvements) yet? I'm replacing my Q9450 with a E8600 (Q822A435 batch) because high FSB (for quad) + high RAM clocks just didn't work well.
I found a webshop that had all Q822A435 procs in stock :)
There you go for the new one: http://www.xtremesystems.org/forums/...d.php?t=201035
Thanx to pmp:clap:
ooh new BIOS! For me about the only thing they can improve over the great 0505 is if they get the 266 strap working.
*I hope they didn't break anything*
Personally I'd've like to have seen some more mem dividers, a choice of 1440 or 1800 is a bit meh. Also, doesn't seem to have done anything for the ability of the board to push a Yorkie, although I seem to be able to run with a lower vTT.
the link is a few posts above
