wrong thread cause they both look the same
I did some research for y'all. It's a E6420 versus my brand new E6850 on my P35-DQ6. I used a Kill-A-Watt to measure power consumption.
Summary:
1. The E6420 kicks its own butt, as it can OC to 3.2GHz at its stock voltages on this MB!
2. The E6850 kicks everything, as it can OC to 3.6GHz at stock voltages and uses less power while doing so; 20W less at 3.0GHz! 10W at idle! Thus, with this CPU, I can idle at the 3.6GHz setting, and use very little power, but it will use 80W more when fully loaded. It's the best of both worlds: low power when idle, high power when not idle. Now if only nVidia can do that...
3. I couldn't get 3.8 or 4.0GHz at "auto" voltages". Trying not spend too much time OCing this thing...
4. Using "Auto" voltages on this MB makes power consumption go through the roof.
Setup:
- P35-DQ6
- ambient temp around 76-80F
- F5g BIOS (F5L didn't work as well at 445FSB, 2.4x mem multiplier)
- 2.4x mem multiplier seemed the most stable
- dual 24" LCD monitors
- mem at 2.0V 1066MHz 5-5-5-5-9 (except at 375MHz, where it is 900MHz)
- nVidia 8800GTX BFG OC 600MHz/900MHz
- Scythe Ninja cooler with NExus 120mm fan at 12V
- Corsair 520W PS; at this power range it is around 85% efficient, so I included these numbers
- APC UPS used 30-35W at idle; the two monitors together use 86W; thus PC box is using around 120W less than shown, and PC parts are using 85% of that number
- In the lowest idle case, it's (300W - 120W = 180W) * 85% = 153W
- In the highest OC case, it's (444W - 120W = 324W) * 85% = 275W, thus the CPU and associates VRMs are consuming 122W more over minimum!!
- Temps aren't final; burn in time was around 30 seconds; TAT was used for burn in and temp reading
E6420, B2 stepping
- In Windows, idle:
- 133MHz FSB bus, all stock voltages (0.8GHz 6x) - 35C - 306W - (underclock, and memory was at 533MHz - since CPU was same temp, 35C seems to be min temp)
- 266MHz FSB bus, all stock voltages (1.6GHz 6x) - 35C - 310W
- 333MHz FSB bus, all stock voltages (2.0GHz 6x) - 35C - 310W
- 375MHz FSB bus, all stock voltages (2.25GHz 6x) - 35C - 311W (mem at 900MHz)
- 400MHz FSB bus, all stock voltages (2.4GHz 6x) - 36C - 312.5W (mem at 1000MHz)
- 445MHz FSB bus, "auto" voltages (made 1.46Vcore) (2.67GHz 6x) - 44C - 340W
- In Windows, TAT on both cores:
- 133MHz FSB bus, all stock voltages (1.066GHz 8x) - 44C - 335W - (underclock, and memory was at 533MHz)
- 266MHz FSB bus, all stock voltages (2.133GHz 8x) - 50C - 366W
- 333MHz FSB bus, all stock voltages (2.666GHz 8x) - 54C - 380W
- 375MHz FSB bus, all stock voltages (3.000GHz 8x) - 58C - 389W (mem at 900MHz)
- 400MHz FSB bus, all stock voltages (3.200GHz 8x) - 60C - 396W (mem at 1000MHz)
- 445MHz FSB bus, "auto" voltages (made 1.46Vcore, up from 1.35Vcore) (3.56GHz 8x) - 66C (30s burn in time) 444W - Got BSOD from heat? Normally single thread prime stable.
E6850, G0 stepping (memory is at 1068MHz in most cases)
- In Windows, idle:
- 333MHz FSB bus, all stock voltages (2.000GHz 6x) - 19C - 300W
- 356MHz FSB bus, all stock voltages (2.136GHz 6x) - 19C - 305W
- 400MHz FSB bus, all stock voltages (2.400GHz 6x) - 24C - 305W (mem at 1000MHz)
- 445MHz FSB bus, "auto" voltages (made 1.44Vcore, up from 1.32Vcore) (2.136GHz 6x) - 26C - 328W
- 333MHz FSB bus, all stock voltages (3.0GHz 9x) - 39C - 367W
- 356MHz FSB bus, all stock voltages (3.2GHz 9x) - 42C - 376W
- 400MHz FSB bus, all stock voltages (3.6GHz 9x) - 47C - 386W (mem at 1000MHz)
- 445MHz FSB bus, "auto" voltages (made 1.44Vcore, up from 1.32Vcore) (3.560GHz 8x (not 9x)) - 54C - 416W
Why does my Gigabtye keep on restting to stock speeds after every reboot even after I set the correct voltages?
http://img168.imageshack.us/img168/6378/36ghzrz0.jpg
http://valid.x86-secret.com/show_oc.php?id=226328
http://img112.imageshack.us/img112/4421/superpi2zd9.jpg
SuperPI
http://img263.imageshack.us/img263/84/img1828ft1.jpg
http://img505.imageshack.us/img505/9715/untitledon4.jpg
Gigabyte P35 DQ6
C2Q 6600
2 x 1GB Corsair XMS2 DDR2 800 c4
2 x 1GB Kingston value ram DDR2 800
Palit 8800GTS 640mb
4 x 74 GB WD740 Raptor Raid 0
2 x 500 GB Samsung 501LJ
LiteOn Super all write 16x
Plextor 716SA 16x sata
Xfi Xtreme Music
HEC Zephyr 750 watts
ThermalTake Aquarius II
ThremalTake Xaser III
Logitech 5300
LG L226WTQ
Hi,
Anyone knows if P35-DS4 (with Silentpipe, not later revision) can accomodate
Thermalright SI-128
http://i80.photobucket.com/albums/j1...ightSI-128.jpg
and MSI NX8600GTS-T2D256EZ?
http://i80.photobucket.com/albums/j1...56EZback-1.jpg
Please advise :)
It does not like what you entered in bios.Give it what it wants and it does not happen.
I don't own a DS4 but I think so.
If you see the heatpipes of the DQ6 which is larger than a DS4, you can fit a 8800 GTX. Moreover under the first PCI-E there is no high components.
Moreover the heatpipe on you 8600 GTS as some clearance between the base of PCI-E slot and the heatpipe.
In my opinion it should fit without problem.
Do you mean anything over 266fsb?
hey guys i just got my water setup on my e6600 im uisng a Gigabyte GA-965P-DS3 Socket
ive been having problems getting to 3.6ghz at 1.4vcore would i be better off getting a new bios?
im still using the bios i got with the board.
cheers.
u should try posting in ga-965p thread not the p35
http://www.xtremesystems.org/forums/...09719&page=191 :up:
oops nice one,
read page 29
yea i seen that but for the life of me i can not make out where lol. i am color blind makes thing little hard see. o well thanks!
yes i can see your marks now thanks! (red is one of the colors that blend in but if i have idea where to look long and hard enough i can see it lol)
i guess the 3 boards i bought not good enough proof
you think i cant use a voltmeter
and the last one i got is overvoltin the worst
2.1=2.26
2.2=2.40
what you call that
voltmeter is digital so i can read:rofl:
i can rewire a house so i know my way around electricity lol
What BIOS gives best performance, F3 or F5G (DS4)? Has any1 compared both those yet, I've skimmed through all pages but only found comments on F3 being faster than F4 and F5 faster than F4 but how about F5 vs F3?
I think they are the same in real app performance. From my...er...feeling, i think F3 is just a little faster but F5 gives u better clock.
