Q9650 @ 4350MHZ 4 x 1GB @ DDR 1210 CL5
Finally got some time to play about with my UD3P over the weekend & I got to say this is a strong board :up:
I run 10H of prime @ 4350mhz with 4 x 1GB sticks of ram on the 266 strap & my HD4870X2. My DFI LP UT P45 run out of puff at 4350mhz on the 333 strap & it didn't like my 4870x2 much either so all in all Im a happy Gigabyte camper.
The Everest read & latency are a little down on the DFI but thats just a tweaking thing. I ran my mem a tad slacker the PL on channel a @ 8 instead of 7 on the DFI & the DRAM "Performance Enhance" was slackened off to standard to keep the NB voltage low.
Here's what I did to get her stable.
CN :)
GIGABYTE GA-EP45-UD3P (BIOS F4)
INTEL CORE 2 QUAD Q9650 YORKFIELD 3.0GHZ 12M L2 CACHE (Q820????? / E0)
OCZ PC2-8500 SLI 4 x 1GB PN:OCZN1066SR2GK
GECUBE HD4870X2 1GB (8.12 DRIVERS)
1 X HITACHI DJ 80GB HD
SONY DUAL LAYER DVD RW (DRU-820A)
OCZ GAMEXTREAM 700W PSU
WINDOWS XP PRO SP3
CPUCOOLING: WATER 1/2" TUBING, D-TEK FUZION V1 (4.5MM NOZZLE), LAING D5 VARIO, PA130.3, 3 X 100CFM PANAFLO 120MM FANS
Code:
******Gigabyte EP45 UD3P******
Q9650 484 X 9 4350MHz
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ 0 ]
CPU Frequency 4.35GHz...........................[ 484 x 9 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 484 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[ 1000mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 50ps ]
******DRAM Performance Control******
Performance Enhance [Standard]
Extreme Memory Profile (XMP)....................[ Disabled ]
(G) MCH Frequency Latch.........................[ 266MHz ]
System Memory Multipler.........................[ 2.50A ]
Memory Frequency 1066...........................[ 1210 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD............................................[ Auto ]
tWTR............................................[ Auto ]
tWR.............................................[ Auto ]
tRFC............................................[ 35 ]
tRTP............................................[ Auto ]
Command Rate (cmd)..............................[ Auto ]
******Channel A Timing Settings******
Static tRead Value [ 7 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
Static tRead Value [ 6 ] ................[ 8 ]
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.23750 ]...................[ 1.42500 ]
CPU Termination [ 1.20 ]...................[ 1.40 ]
CPU PLL [ 1.50 ]...................[ Normal ]
CPU Reference [ 0.766 ]...................[ Normal ]
MCH Core [1.1 ]...................[ 1.300 ]
MCH Reference [0.760 ]...................[ Normal ]
MCH/DRAM Refernce [0.900 ]...................[ Normal ]
ICH I/O [1.500 ]...................[ Normal ]
ICH Core [1.100 ]...................[ Normal ]
DRAM Voltage [1.800 ]...................[ 2.180 ]
DRAM Termination [0.900 ]...................[ Normal ]
Channel A Ref [0.900 ]...................[ Normal ]
Channel B Ref [0.900 ]...................[ Normal ]
******Advanced BIOS Features******
CPU Multithreading..............................[ Disabled ]
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
PRIME95 + 2x CPU-Z, CORETEMP & MEMSET
http://i106.photobucket.com/albums/m...Hz/10HStop.jpg
EVEREST CACHE & MEMORY:(READ 10124MBS LATENCY 50.8NS)
http://i106.photobucket.com/albums/m...ry4x1GBStd.jpg
3DMARK2001:(SCORE 82718)
http://i106.photobucket.com/albums/m...z/3DMARK01.jpg
3DMARK2003:(SCORE 82612)
http://i106.photobucket.com/albums/m...z/3DMARK03.jpg
3DMARK2005:(SCORE 30062)
http://i106.photobucket.com/albums/m...z/3DMARK05.jpg
3DMARK2006:(SCORE 24487)
http://i106.photobucket.com/albums/m...z/3DMARK06.jpg
AQUAMARK 3:(SCORE 261,172)
http://i106.photobucket.com/albums/m...z/AquaMark.jpg
SHORT DESCRIPTION:
484 x 9 = 4350MHz @ 1.40v
4 x 1GB 5-5-5-15 2T @ 2.18V DDR 1210
