not yet...
not yet...
Abit 12 bios working quite good with the E8400
Max Bus 560 FSB 2243
http://www.imgx.org/thumbs/small/11661_2l3lr/560.jpg
24/7 500x8 4ghz 1.28v
http://www.imgx.org/thumbs/small/116...4000stable.jpg
what kind of vtt and gtls settings are you using on 500x8? I've got nearly the exact same setup and i can do 485x8 rock solid, but 490x8 is unstable regardless of the cpu voltage (I have tried 1.3 plus). I know i havent hit the fsb wall yet.
using 1.2v cpu
vtt 1.25
gtls 67 etc
Is there anyone using MCW30 to cool northbrigde of this board?
http://www.koolance.com/water-coolin...product_id=437
maybe this one would fit on the board.....
Is this board better then a Asus Maximus Formula?
This is what my E8400 is doing on this board with latest official release bios
E8400 + Abit IX38 @ 572 FSB :D
Following the link it says DICE ;)
I had the same problem once when using another board. It was caused by insufficient voltage supplied to one of the components in the motherboard.
My problem before was solved by raising Vcore one step.
May be you should consider raising your voltage too, one or two steps m8, and pray that it helps. :yepp:
This might help you ;)
Really want a new bios to :)
Its done with DICE. Trying for more. Too bad this board doesnt support Memset,it becomes a pain when you want to bench at high clocks.
Atleast Abit should include memory timings thing in uGuru :(
