Originally Posted by ubern00b
Hi All
If this has been answered before I appologise, I tried reading the whole thread and didnt see any answers to my questions so here goes:
ClockGen, what PLL should be used?
Anyone have any issues with using MemSet? I am using 3.2 but will try 3.1 or 3.0 as I have seen screenshots of others using the older versions. When I try to set any timings in MemSet, if I go to CPU-Z it cannot seem to read the timings back, and if I reopen MemSet it cannot display the timings either. I have to reboot to get CPU-Z to show the timings again.
Also, I dont know where this fault lies but I am running Crucial Ballistix PC2-5300 RAM and on default SPD its running 4-3-3-12 @ 400mhz. If I change the Bios to manually configure the timings it doesnt seem to matter what I set the last digit to, it is always 18. so setting 4-4-4-12 in the bios results cpu-z showing 4-4-4-18. Anyone else with this problem? I was thinking of taking the ram out, resetting the bios and turning the pc on with no ram in it to try sort of hard reset the settings and see if it makes any difference.
Hope someone can be of help. Thanks!
