nice avatar, do you have it in larger?
hehe soulman it looks like your avatar got some marks on her back ^^ looks ugly
Looks like kind of a light load for such a big rad, I'd be surprised if it couldn't keep such low temps. Most ppl here could run that on a PA120.3 with only slightly warmer temps (if not equal). It also puts a massive burden on your pump with all the 180° bends, restriction wise, that's probably at least 10 PA120.3's worth. What was the load and how long was it applied?
Long time lurker, first time poster:
http://i79.photobucket.com/albums/j1...ld/CPUShot.jpg
http://i79.photobucket.com/albums/j1...d/SideOpen.jpg
http://i79.photobucket.com/albums/j1.../Sideshot2.jpg
It was a fun little project, but I've already received my next list of parts which I hope to post in a few weeks.
First off, :welcome: to XS!!
Very nice build m8!! looks great! :up:
And I like that custom window!!!
:welcome: to XS! Great cable management :up:
Thanks for the kind comments. No, this is not my first WC setup, nor will it be my last. Thanks for the input guys!
Mine is kinda junky. Gotta chop off all the extra tubing, put in a t-line, put in better coolant, do a bootleg fan mod so I can cool my ram better, and turn by rad around. I was bored as hell, so I made a vid. Its pretty bad because I didnt edit it yet.
http://i275.photobucket.com/albums/j...h_DSCN6007.jpg
http://i275.photobucket.com/albums/j...h_DSCN6006.jpg
http://i275.photobucket.com/albums/j...h_DSCN6005.jpg
#2 and 3 are about the same thing.
You must have been really bored to feel a need to make videos of your computer. I think if you replace the coolant with either blue or clear and cut out all the extra tubing it will look quite nice. I'm not really a fan of it now because the green coolant and all the extra tubing.
thanks all guys...but i thik you like more my avatar than my system:D
<massive burden on your pump> you test this rad? Water stream above than i`am use alphacool GTs 240
<What was the load and how long was it applied> game (assassin`s creed) 2-3 hour, OCCT 1 hour
sory for my English... :D
In general sense of a radiator in that that it big and on it it is possible to hang up many fans and it all the same will be silent and effective.
To me to like.
PA120.3 (PA120.4) very good radiator but it not so will be harmoniously looked on a lateral wall.
Also do not forget all my fans very much very silent and blow poorly
Thanks for your opinion. :toast: :toast:
@Xaviar, it's the same plate but I just drilled the necessary holes..
and thanks
Don't take my word for it.
http://www.xtremesystems.org/forums/...highlight=mora
Just do a search for "MO-RA", "MORA", or "mora" to find many many more topics discussing just how pathetic the rad really is.
Shocker, I like but...I think you need to remove those restrictive Alphacool blocks. I think that's your biggest problem now, that and maybe 12/10 tubing next time, 8mm I.D. is still a bit small.
The reason your temps are high is because having smaller tubing will make the pump push the water through really fast, water going TOO fast by the copper on the waterblock CAN create heat.
You should look into getting chipset blocks like the MCW30's or some EK's, and maybe some 7/16" ID tubing.
You've got quality components in your rig, but you can cool it better with an air cooler compared to some of the watercooling gear you've got in there now.
I think your doing a great job improving on this build, some here might not like some of the things you've got.
But what really matters is if YOU like it and that it WORKS. :up:
Keep up the good work m8!
Ok here is my contribution guys.
CM690 modded and painted. Dual loops with a PA 120.3 on each. The GPU loop is supposed to be SLI but Im waiting on an RMA for the 2nd card. The CPU loop is going to include the FETs and the NB in the future which is why I have it on its own loop.
This is only my 2nd loop ever (first one was about 2 weeks ago) so please feel free to critique! Im not thin skinned and would appreciate any comments or advice.
The wires need a tad more tidying, and I need to trim my fill lines as well as perhaps reposition the one going to the top pump. I also am going to get some modders mesh and make a cover for the lower right open area which used to be HD bays to cover up the wires stuffed behind there.
:D
http://i268.photobucket.com/albums/j...9/P1010046.jpg
http://i268.photobucket.com/albums/j...9/P1010045.jpg
http://i268.photobucket.com/albums/j...9/P1010044.jpg
http://i268.photobucket.com/albums/j...9/P1010043.jpg
http://i268.photobucket.com/albums/j...9/P1010042.jpg
WOW! Excellent job there m8!! :up:
Looks great. What GPU block(s) are you using? MCW60 or D-Tec GFX?
MCW-60 :)
I think its a decent job, but Im really not happy with the position of the top pump located a the bottom of the 5.25 bays. You cant see it, its hidden in those pics from the fill lines.
Thx for the encouraging words :)
Any recommendations/suggestions always appreciated.
