yes it is aluminum, its a great case, just the reversed cooling... i dunno, i have mixed feelings about it, and not just because it makes my drinks hot on my desk :rofl: I got that case from performance-pcs
cool, maybe I can get Hank to price match newegg :D
heres mine pc7
http://img183.imageshack.us/img183/6...2103ln0.th.jpg
all cool and quiet
You can get all sorts of sound dampening mat. The best are the one's with double layers. First the soft and thick mat that absorbs the sound waves and then the heavy and thin bitumen mat that prevents the case from resonating
http://img471.imageshack.us/img471/5...0053zw4.th.jpg
http://img406.imageshack.us/img406/5...0039ry7.th.jpg
Dual Prestonia M0 Xeons 2.66@3.3GHz on PC-DL with a Leadtek 7800GS, not the most impressive Air Cooling setup! Keeps them under 57*C at full load :)
Mine :) Put blue 120mm Fan in front of the case to intake cool air
http://img132.imageshack.us/img132/2...1772nd5cf9.jpg
http://img357.imageshack.us/img357/4427/53924327ee0.jpg
http://img263.imageshack.us/img263/5048/96312564bu4.jpg
slade you can't seem to make up your mind to stay with either air or water, seems every other week you've changed :p:
http://i7.photobucket.com/albums/y294/vicrol1123/1.jpg
http://i7.photobucket.com/albums/y29...3/IMAG0014.jpg
http://i7.photobucket.com/albums/y29...3/IMAG0027.jpg
the pc of signature.-:rolleyes:
PD: my amb temp is 35º.- :sick:
but i have good temps in the system.
831 Stacker
http://img176.imageshack.us/img176/8499/img4920ls9.jpg
- asus p5w dh deluxe
- e6600 @ 3.6ghz
- 4gb d9gmh
- x1900 xtx
http://img261.imageshack.us/img261/7101/img4892fd6.jpg
- dfi lanparty ultra-d
- opteron 146 @ 2.8ghz
- 2gb ch-5
- 7800 gtx @ 520/680
@Lancer33, Does the Thermalright Ultra-120 comes with dual 120mm fan clips, or just one?
BRendan
my decidedly political E6400 build:
http://resume.jbhfile.com/temp/air1.jpg
http://resume.jbhfile.com/temp/air2.jpg
http://resume.jbhfile.com/temp/air3.jpg
that modified infinity has been such the pwner, that i hate to have to upgrade when the IX-14 is released later this year. assuming the IX-14 is all that it looks like it's going to be that is ...
it's a video editing machine; every PCI slot is full and all cards have 5.25" front panels ... so ... lots of cables.
oh, and pardon the politics ...
cyberspyder,
The Ultra 120 only comes with clips for 1 fan, I have multiple rigs using this cooler so I couls set this one up with clips but you can mount 2 120's using zip ties as shown in the attached photo. Just run one tie through the fans and cooler, use a second tie to lock it and cut everything but the end off of the locking zip tie.
IC, thanks.
StyM, cool decision :). this is smthg like yours, but instead of 2 large ventilators there're 70(!!!) smaller fans :D:
http://www.peteredge.orcon.net.nz/pic_front2.jpg
source: casefancasefancase....... .
