Originally Posted by
pangingIII
Ghostleader,
this's a BIOS setting i used to use for an e8400 450FSB DDR2-1200 tRD7 2x1GB RAM...
if you cannot stable your system with the setting, then try adding more MCH voltage to 1.26-1.30v, and drop the MCH ref. value down from 0.76v to 0.74v, and then try 0.72v and 0.70v. this setting should be working okay for your 450 FSB, CPU at 4.05GHz and running DDR1200.
the memory timing (in the above pic) is standard timing for the HyperX PC2-9600 running at DDR1200,
you can try the timing setting in BIOS, but also set Turbo.
if you want to tighten memory timing then do that once you can get a stable overclock, and then try retesting your system again.
for 500 FSB and up on C2D 45nm, try MCH ref. value of 0.64v-0.70v (of VTT 1.20v),
it's almost like... the higher fsb the lower MCH ref., for booting 600 FSB, i use VTT 1.40-1.46, MCH 1.40v and MCH ref. value of 0.65v.
note-- in order to use the ET6's voltage setting value in your BIOS, for example, if you want to try my voltage setting (above),
the easy way is to first set VTT to 1.20v, Vdimm 1.80v,
and then set the other voltage and ref. settings using the value shown in the ET6 and go back to VTT and Vdimm and change the 2 values last.
i hope this helps.
