Is the download link on the front page the latest bios for asus P5Q deluxe ?
And ore is it rather bug free like it won't destroy annything :p
1.4v would be fine 24\7. Idle and load actual voltage would be below that anyway. Idle it would probably be about 1.38v and load around 1.37v.
Nope. Load = 1.408v. Idle = 1.392v. Both measured in CPU-Z and while stress testing in Orthos small FFT's. LLC is enabled.
Surprised your running LLC. Pushes a lot of things out of whack. No conclusive evidence it kills CPUs, but still, the possibility is there and not just based off smoke fumes.
Without it, vCore is all over the place!
:\ My vcore has always been very stable on the P5Q Pro. Then again, my PSU ain't no lightweight with 80A across the 12v rails. Even running OCCT I think the highest ripple I saw on the 12v rail was 0.46%, which is well within electrical tolerences.
1.425 vCore set in BIOS = 1.408 idle and 1.360 load.
That's pretty bad. I'm keeping LLC enabled. Nothing I ever try can get this CPU past 4.33GHz anyway. Nothing!
How man "spiking" devices do you have connected to your PSU? Yup, you even have to be careful of things like that to maintain stable, clean power by evenly placing "spiking" devices on the PSU.
True I had to spread my shiznit out across my modular because it was having issues with three drives on a single rail , which I rhought would be fine but nope.. It is a silverstone 750W modular one to, no cheapy..
Interesting. So how do I set them up evenly? I hate cable clutter!
Oh, one other thing: I have a "Turbo" mode on this PSU which supposedly combines all 6 rails. That's actually a lie, I don't even think this PSU has 6 rails. Maybe I shouldn't have it on Turbo?
901m bricked my p5q pro.. tried everything.. cmos.. holding power down.. no battery.. is there a more stable bios?? or whats the one you recommend for a p5q pro.. and which program to flash it? i got another one..
Basically, make sure all your spiking devices aren't on the same line. For example; have your SATA drives on one line, then use another line for other devices like optical drives, then a 3rd line for things like fans.
What were you doing for 901m to brick your board? I was using 901m prior to my.. "experiment", and it was rock solid. As already said though, 703m is a great BIOS so go with that to start :up:
Hi ket nice to meet you myfriend:)
I have a P5Q non Pro and upgraded to your mBios 1307 and i had no problems at all like crashes BSODS no POST nothing at all and my PC works like a charm now thanks to you :up:
say would you be kind and add the P5Q Premium OC Settings to the other P5Q Series so that everybody will enjoy great OC?
Settings Like:
DRAM CLK Skew on Channel A1
DRAM CLK Skew on Channel A2
DRAM CLK Skew on Channel B1
DRAM CLK Skew on Channel B2
CPU GTL Voltage Reference 0/2
CPU GTL Voltage Reference 1/3
NB GTL Reference
btw:I Dont know you but i know a little about you like:the good:
You are sesetive person and introvert and you have internal rich world and developed imagination and you have a strong connection to home and family and mostly the mother character and developed ability to care listen and understanding ability and developed memory ability
The bad:low self esteem difficulty in making changes and deeply need in secured environment and difficulty in simple thinking and wide catch of reality
subjective catch in essence
note:it seems you are a very vulnerable person that never forget who hurt him
what do you think of this analyzing? i hope youre not hurt of the analyze cuz you see its just analyze nothing more so tell me what you think of it.
btw2:i found a website that has all the tools asus have and as you said you dont have all of them so tell me if you want the link to it or you can PM Me
Thanks in advance myfriend:up::up::up:
LMAO wtf is wrong with the above past, rofl, you just made my day sir!
Heh heh heh.. too funny.
I think I speak for everybody when I say :gay: :p: I will be adding what I can
when I can test the BIOS, which will be when my P5Q board gets back from RMA. Also, are you like my internet stalker or something? :p:
Any links you have for asus tools post up, I'm sure I'm not the only BIOS modder out there!
i tried to just load the bios... w/ ezflash through my usb drive and bam i restart the computer and no post.. so you reccommend 703?? is that one of the most stable and best bios revisions u make?? i gotta p5q pro / e8400 / ocz reaper pc1066 ddr2. lookin to get it up to 3.8-4.0..
what do you recommend to update the bios? aiupdate? ezflash? afudos?
EZ Flash should work just fine. Did you load default BIOS values before you flashed? This is important.
no ididnt.. should i clear my cmos before i flash the new bios? and obviously after the flash.
Do as Dee suggested. Also, do NOT use any mBIOS I have not included in my first post. I think a few people have quoted me when I done those BIOS files that pushed things a bit far and as I cant remember my password an stuff atm I can't pull the files from the server until my main system is up again.
