WFO, I just found this info in the Intel section of the board. It is an OC Q6600 voltage chart! I guess me having to run a
1.55v core setting in the BIOS to get 3.9GHz, isn't as dangerous or uncommon as I origionally had thought.... :up:
Have you seen this?
http://www.xtremesystems.org/forums/...d.php?t=157690
Q6600 Table-----------------------------
Q6600 G0 - L727A856 - 4.36Ghz P stable - PC (custom) -
1.7v - Asus P5K-E - by -------------------jinu117
Q6600 G0 - L737B186 - 4.01Ghz - WC (custom) - 1.504v - ASUS P5K Prem - by --------------------Devious
Q6600 G0 - L727A934 - 4Ghz P stable - PC Vapo LS - 1.425v - ASUS P5K Prem - by ----------------dragonhunter
Q6600 G0 - L723A795 - 4Ghz P stable - PC jinu117 - 1.485v - ASUS P5K Prem - by -----------------billdavis
Q6600 G0 - L724A629 - 4Ghz P stable - WC D-Tek Fuzion -
1.6v - EVGA 680i - by ------------------turtletrax
Q6600 G0 - L724A784 - 4Ghz P stable - WC D-Tek Fuzion -
1.62v - ASUS P5K Prem - by ------------TinTin
Q6600 G0 - L723B010 - 4Ghz (500x8) P stable - WC D-Tek fuzion -
1.64v - ASUS Blitz Formula - by---Ic3man
Q6600 G0 - L725B057 - 3.9Ghz P stable - WC D-Tek Fuzion - 1.496V - ASUS P5K-E - by ------------dj883u2
Q6600 G0 - L723B284 - 3.9Ghz P stable - WC Apogee GT - 1.52v- DFI P35-T2R - by - --------------RLM
Q6600 G0 - L726A840 - 3.9Ghz P stable - WC Apogee GT - 1.5375v - EVGA 680i - by ---------------CraptacularOne
Q6600 G0 - L726A822 - 3.9Ghz P stable - WC D-Tek Fuzion -
1.58v - ASUS P5K Dlx - by ------------rbsmontemor
Q6600 G0 - L726A951 - 3.85Ghz P stable - WC D-Tek Fuzion - 1.52v - ASUS P5K Dlx - by -----------no_n|ck
Q6600 G0 - L726A850 - 3.85Ghz P stable - AC TR Ultra 120 - 1.537v - ASUS P5K Dlx - by ----------crossg.
Q6600 G0 - L727A918 - 3.82Ghz P stable - WC Apogee GT - 1.52v - ASUS Striker Extreme - by -----linflas
Q6600 G0 - L724A*** - 3.82Ghz P stable - WC D-Tek Fuzion - 1.54v - ASUS Striker Extreme - by----nugzo
Q6600 G0 - L723A674 - 3.81Ghz P stable - WC Apogee GT- 1.54v Gigabyte DS4 - by ----------------aspms*
Q6600 G0 - L731B163 - 3.8Ghz P stable - AC Tuniq Tower - 1.525v - Maximus Formula SE - by ------loc.o
Q6600 G0 - L726A*** - 3.8Ghz P stable - WC - 1.43v - ASUS P5K Dlx - by -------------------------njkid32
Q6600 G0 - L727A673 - 3.8Ghz P stable - AC TR Ultra - 1.472v - Gigabtye P35-DQ6 - by ------------dertimaushh
Q6600 G0 - L720B066 - 3.8Ghz P stable - AC TR 120 -
1.5v - Abit IP35 Pro - by --------------------Ace-a-Rue
Q6600 G0 - L726A849 - 3.8Ghz P stable - AC TR Ultra 120 -
1.5v ASUS P5K E - by ------------------sam95ta
Q6600 G0 - L724A*** - 3.8Ghz P stable - WC Apogee GT -
1.55v - DFI P35-T2R - by ---------------RLM
Q6600 G0 - L719B278 - 3.8Ghz P stable - WC D-Tek Fuzion -
1.6v - Abit IP35-Pro - by - ------------vkostas
I now think I can set my CPU core voltage higher than 1.555v's in the BIOS, and expect my CPU should be able to brunt it fine! Especially on water...
In case you guys havent figured it out yet, I'm a charts and listings guy!! ;)
Raw data is my :banana::banana::banana::banana:! ;)
