Video Card Builders, What GPU and Brand Do You Like?
EDIT @ 02-23; Why the ignore? I pull over to ansewer questions for the foum.
Can I get a feedback on the various graphics card builders you gamers and or overclockers use and a brief or detailed reason for your choice when using on this ASUS x38 and or X48 mobo?
I'm looking for input on such builders as Sparkle, Apollo, Zotec, Saphire, Galaxy & Palit as far as anything in general.
I am also interested in reasons for choices of the big names like ASUS v/s Gigabyte, nVidia, MSI, LeadTeck XFX, EVGA, BFG and so on.
What brands are best chosen for what GPU chip (ATI or nVidia)? Which are chosen for either best quality v/s performance on a budget?
Thankx for your time.
Reload ACPI ATK Drivers In VISTA x64?
After experiencing some issues with a process named aacenter.exe from ASUS AASP folder. I stopped the process and then moved it for testing since I could get no help on what to do about it. Now I have al kinds of issues with ACPI suspend modes especially simple S3/S4 resume. How do we fix or reinstall correct ACPI for this mobo? I see an ATK fix on Windows downloads but it cannot install. In fact it has never installed and keeps saying failed since new VISTA install.
Prior to this, OC was nice and smooth and full ACPI worked in BIOS v1207 be it slow that it was, but it worked.
AmI looking at a new install just to fix? When and if I do, do I leave out the ASUS ProbeII or any other ASUS app that places the AASP folder and aacenter file in system?
So sad, err, angry, no sad, actually both!
Hello All:
Been a lurker here forever and a member for almost a year but this is my first post. :) I just wanted to start by saying what a great community, I've learned a lot here.
Well, here's my issue:
Can't seem to post my brand spanking new q9650 at 4ghz (a couple of times I've gotten to right before Windows boots but that's it). With this setup and these settings, I should at least be able to boot into Vista to stability test. I've kept roughly the same settings and have slowly increased the vcore from 1.29375 to 1.34375 (should at least boot at that voltage). CPU VID is: 1.2375. Here are my BIOS settings:
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 450
FSB Strap to North Bridge : tried both 333 and 400
PCI-E Frequency: 101
DRAM Frequency: DDR2- 900@400strap & 1069@ 333 strap and 445fsb
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
Ai Clock Twister : Strong
Transaction Booster : Disabled (also tried enabled)
CPU Voltage : 1.34375
CPU PLL Voltage : 1.56
North Bridge Voltage : 1.63
DRAM Voltage : 1.9 (board overvolts to 2.04)
FSB Termination Voltage (VTT): 1.36
South Bridge Voltage : 1.10
Loadline Calibration : Disabled (also tried enabled)
CPU GTL Reference : .63x
North Bridge GTL Reference : .67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : DDR_REF
SB 1.5V Voltage : Auto
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED : Enabled
Advanced CPU Configuration
CPU Ratio Control : 9
C1E Suppport : Disabled
CPU TM Function : Enabled
Vanderpool Technology : Enabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
