can not change cas latency with 965GM chipset felix
it wont even let you select anything, the drop down works but if you click on 4 or 5 or 6 or 3 it doesnt change it stays at cas5.
you cannot change the cas latency using memset (mentioned a few times in this thread :p: )
cpu-z may have registered a change in cas, but there was no performance benefits, meaning the change did not actually work
Please add a support for VIA KM400/400A VenID/DevID 1106/3205
If change all 06118931 to 06110532 - it all works perfectly.
Thanks FELIX! Everything works fine by the first look. Here are my results with a pair of PQI ram modules:
http://img402.imageshack.us/img402/5...msetom0.th.png
Will there be more timings to tweak in the further versions or 965 mobile chipsets are only limited to this ones? I would like to play with tRC a bit. :)
Hope you can get the Skulltrail update done soon ;)
->compiller: VIA don't provide any datasheet for their chipsets, so impossible to
add support .
->FUGGER: it's a server chipset, without most important timings (CL, tRCD, tRP and tRAS are not documented)
I'll try to update in 3.5 version.
Here is what I can see now, the version you emailed works.
Felix,
Thank you for your great MemSet. I have just migrated from Athlon64 X2 3800+ @2.6Ghz to Q6600, currently running 3.0GHz (333x9 / 333 strap) (on retail stock cooler), so excuse me for a newbee question...
... I set Command Rate to 1T in BIOS (Asus P5K vanilla). CPU-Z 1.43 shows Command Rate 2T ?! Now the interesting thing : I launch MemSet, within 2 secs CPU-Z shows Command Rate 1T !!! I exit MemSet, CPU-Z shows 2T again :confused:
To your knowledge, is this a CPU-Z bug ?
Thanks again,
Dominique
P5K v1.02G
Q6600 G0 @ 333x9 on stock air / 1.375v BIOS / 1.33v Idle / 1.27-1.23v Load
OCZ Reaper 6400 @ DDR800 4-4-4-15 1T (???)
7600GS /512 Silent + 7600GS /256 Silent
Antec Sonata III w/ Earthwatt 500W
Does 3.5 Beta work on Abit IX38 QuadGT ?
It should buddy... why dont give it a try and then feedback!!
@FELIX : not working on ABIT IX 38 QUAD GT with Memset 3.5beta
and what is the problem?
I cant use memset 3.5beta.... like crash on memset, only work double click shortcut and exit on tab in memset..:)
That's my problem on Vista x64, displays and that's it with 35beta.
Oh and put a link on your website to get/try the beta's.
Ty
...when Apply and Save button isn't show, it's cause the MCHBAR is locked in Write.
You can check it by: Open WPCRedit on PCIBus :0 Device:0 Function:0 and look at
OffSet F4, bit[0] :if it's at 1, MCHBAR have been locked in write by the bios.
And unfortunately, it's a "read only" bit, You can't write 0 in this bit.
Abit ip35pro latest beta bios. It doesn't work as usual
Nice find, works well.
:) works really great on my abit nf-7s whit a-data vitesta pc4000.
I'm testing beta for now it's stable for me. next week i'll get new memory and mobo we will see :)
Good job Felix
I can run 3.4 fine, but 3.5 says "unable to execute file in temporary directory" Error 5 Access Denied" when I click on the downloaded file. Any ideas why?
I moved it to an empty folder and then it ran the setup.
Felix here's MemSet 3.5 beta on my EVGA 780i. Has it been updated for the 780i chipset or is it normal to see NVIDIA NForce 680i SLI?
Attachment 72820
->xgman: no idea, perhaps cause the executable file is not in a good folder... :confused:
->msgclb: I know this "problem", cause 680 and 780 have the same device ID, Same thing with X38 and X48:
I need to find an other way for identified these chipsets...
