Hey Perc you using winnie?
If so vid over 1.45 = 1.4, 1.4 = 1.36 and so forth.
After 1.45 need %vid to up vcore, winnie screwiness - think this is sorta mentioned up front on the thread now? (Winnie self-defense mechanism?)
This applies for winnies only AFAIK
Also I set AGP to 67 on general principle :D
Yeah gotta do some stuff on the board FH
Originally Posted by FlyingHamster
I also got the Zalman CNPS7000B-AlCu, and was wondering if I have to take off anything on my k8n neo2 before installing it. anyone know?
Yeah loose the top & bottom (bottom extrusions through the holes muck everything up :mad: (much easier to bottom remove b4 you use it, use hair drier on bottom if needed), then replace bottom plate w/ the zalman and screw in the brass standoffs. Assuming you haven't removed the heatspreader on chip should be good to go. While your at it, redo the paste on the NB and maybe lap it? b4 putting it all in the case.
We await results! :D
