http://www.tweaktown.com/pressreleas..._e3/index.html
hmmmm :)
Oh men! If its real, is it awesome!
http://img215.imageshack.us/img215/8...46c800x600.jpg
That is one funky box! Perfect for coffee storage.. :D
there are more pictures
http://gathering.tweakers.net/forum/...78456#36178456
also on the turbo
http://tweakimg.net/g/forum/template....com/Erqeq.jpg
if this is real that it would mean that turbo 2.0 can even have different GHZ and multipliers within a single module.
From Dresdenboy's blog ,a great question :)
So,at which clock all these parts run if both cores are having different clockspeeds? :)Quote:
Originally Posted by Dresdenboy
My guess is that all shared parts ,except FlexFP,run at the frequency of higher clocked integer core :). FlexFP is usually clock gated if no fp commands are scheduled,but if it is not clock gated it should also run at the frequency of higher clocked integer core.
http://i56.tinypic.com/jhemx3.jpg
BD in overdrive
chili sauce: http://www.4gamer.net/games/100/G010000/20110607029/
Every single core at diff frequency?
Every core at different frequencies is a bit strange when you consider the modules.
been dying to get a good side view of the new box ;) :D
I don't think so... It can have one fast core or two with the others being throttled, but nothing similar to this that I know of.
It would make sense if frequency at least changed according to core's load... But look at the above screenshot: 2% load and 3.2GHz, 14% load and 1GHz? :confused: Maybe it's set manually this way...
Diamond: hehe , u change Avatar ,-). I try use it as my desktop in windows :), They wrote, this BOX is only for 8-cores (maybe only topmodel)
What is strange is that every voltage is at 1.4V
What does he say at :05, " use the air spots controller"?
http://www.youtube.com/watch?v=ZUIO7pLCCbE
If its marketed that way as an "ultimage gaming cpu" , it cant be worse than current SB in games as some people suggested.But thats probably due to the aggressive turbo.
wow those box is for candy?
http://img.donanimhaber.com//images/...3a_dh_fx57.jpg
I feel a new stepping coming for christmas.
And the other thing, current models look like are scheduled for start of Q3, so maybe theyre gonna show up in the summer itself and not in september.
Yes,late July seems to be the target now. Shouldn't be long now :D. Turbo is going to reach some new levels with Zambezi.
