Anybody tried or had issues with Kingston HyperX DDr3 2000 RAM and this mobo?
http://www.newegg.com/Product/Produc...82E16820104082
My result @ 19*219MHz with plain water cooling:)
Prime Blend 1Hr Stable
http://www.vmodtech.com/files/prime-219_204.png
Nice Venom. My Feser 480 rad arrived the other day, so will start to build up water cooling loop so can start testing my i7 920s on H20 instead of air sometime this weekend :)
yup fine balance for all voltages and each memory kit and cpu combination will have a difference balance even for same model/speed memory kit. But i've never corrupted my bios as yet :)
9-9-9-X Kits most likely Samsung HCF0, so shouldn't have problems. If you have the 6GB Kingston HyperX T1 DDR3-2000Mhz 8-8-8-24 kit then they're the new Elpida 50mm Hyper ICs same used in Corsair Dominator GT 7-8-7-20, OCZ Blade PC3-16000 7-8-7-x and G.Skill's Perfect Storm DDR3-2000 7-8-7-x.
If you have these Elpida, SOME kits might need to do some ADDR/CMD Bus VREF tweaking.
ADDR/CMD Bus VREF set at 105 @DDR3-2209Mhz 7-8-7-20 2T at 1.92v vdimm bios set (1.925v real DMM).
http://fileshosts.com/intel/DFI/DFI_...1m18s043ms.png
Validation is at DDR3-2209Mhz just cpuz clock momentarily jumped to DDR3-2212Mhz :)
http://fileshosts.com/intel/DFI/DFI_...cpuz_valid.png
@DDR3-2286Mhz 7-8-7-20 1T at 1.875v vdimm bios set (~1.880v real DMM)
Still not close to my best I did when i first got my GT set with DFI UT X58-T3EH8 with 1/23 beta bios.
Validation
http://valid.canardpc.com/cache/banner/500527.png
Thanks alot eva2000. Just have to find them in stock somewhere.
EDIT: Kingston's site shows them to be out of stock until 6/10/2009!!!!
well eva not suprised with the vref
with the r2e when i was getting the 2000 CL8 stable on that board i had to set -12.5mv. reminds me of rampage extreme kekke
but the rtl really helps a lot on 1n settings vs 2n.
thats how i got a lot of the 1n stable at 2n voltages.
usually channel a vs channel b is +1/+2 and channel c is +2/+3 of channel B
btw left it at auto because of this
is there something wrong with the vref
if on stress if bsod .. prime 95
say set all 3 to 95.
if bsod
go back to bios channel b will be 94 and the rest at 95
Never used R2E board so not familiar with settings in bios so not sure what +1/+2 vs +2/+3 denote ?
I asked DFI about channel b resetting to 94 or 1 below others, and they said it's because it's last bit of 32bit range which they don't use and shouldn't matter as it's only 0.4% difference. Now no idea what that means :o
As to BSOD probably still need for cpu vtt/vdimm and IOH/ICH voltages to be balanced. Or we need to fine tune ADDR/CMD Bus VREF channels individually ?
Pulled this off with ADDR/CMD Bus VREF = 100/100/100 set in bios.
http://fileshosts.com/intel/DFI/DFI_...9m04s584ms.png
the for the RTL
in r2e u can set for channel A, B, and C.
ure setting shows channel A in cpu tweak
+indicated addition of channel A since channel A is the base rtl
in r2e norm for Channel B to be +1/+2 of Channel A,
Channel C to be +2/+3 of Channel B
higher mem multipliers and timings lower channel A, example 1600 CL8 is around channel A 60+, CL7 is 50+
2000mhz CL8 50ish but somewhere near 60
2000mhz Cl7 is 50+
this was what i found out with r2e.
but whatever i did still couldnt run the sticks at CL7 2000mhz on that board only CL8
something like that. the r2e ..usually instability is the same like dfi except when bsod the RTL changes.
I see... maybe your cpu's IMC coming into play for CAS7 vs CAS8 as well ???
what's max temp recommended for PWM and Chipset ?
found a flaw eva on this mobo
will call dfi tommorow
flaw
set two gc in sli
and one x1 pciex sound card..
second card running in 8x.
wish dfi was like asus .. to have a option to force 16,16,1
it only runs 16,16,1 if no card is inserted in pcie 3.
any insert will result in 8x on pcie 2
UT X58 PCI-E slot speed:
1 card in one or both green slots - Green slots operate at x16 speed and yellow slot is turned off.
Card in yellow slot - Top green slot operates at x16 speed while bottom green slot and yellow slot operate at x8 speed.
The above is how the board is designed and no other configuration is possible.
so what bios is everybody using now?
sounds like bios related then
PWM 60-95C ? Chipset 35-55C ? Just guessing... for me load temps for PWM between 45-65C and Chipset between 35-50C all stock heatsinks just with fans over them and Flame Freezer installed with ceramique paste.
about right http://i4memory.com/102537-post3.html
PCI-E Assignments
Received some clarification on the PCI-E slot assignments for multi-GPU configurations.
- PCI-E #1 and #4 are x16 when nothing is installed in PCI-E #3.
- When PCI-E #3 is occupied, then PCI-E #1, #3, #4 become x16/x8/x8. This applies to both CrossfireX and SLI.
http://nx.i4memory.com/reviewimages/...assignment.png
Example, with 2x HD4870x2 double slot video cards in PCI-E #1 + #4, you'd block off access to PCI-E #2 x4 slot and PCI #2 slot but still have access to PCI-E #3 (yellow x16 slot - photo below has Highpoint RR3520LF PCI-E raid controller installed) and PCI #1 which is empty below :)
http://nx.i4memory.com/reviewimages/...sfirex_003.jpg http://nx.i4memory.com/reviewimages/...sfirex_002.jpg
http://nx.i4memory.com/reviewimages/...sfirex_004.jpg http://nx.i4memory.com/reviewimages/...sfirex_008.jpg
2/27 beta for now.. can't wait for next DFI bios more mem related options to play with :D
What do you guys AHCI or IDE mode? What ahci drivers do use for proper installation?
Don't know if it's answered in a previous post but...How the heck can I set a non turbo multi over 24x? Can't find it anywhere and the turbo mode doesn't seem to work :( I need it for 3D :(
I hve now 3gb OCz platinium
but vista 32 shows only 2560mb physical memory
Should I try to change LOWGAP setting in order to show correct RAM buffer or leave it on a default value?
has anyone board fried yet or am I the first one ?
i use IDE, AHCI drivers come with SATA matrix intel raid drivers as well. For raid i use 3rd party hardware raid controllers so I can move arrays between different boards without worry :)
never used 965 cpu, but each brand board sometimes have early bios limitations on multipliers - seems DFI is 23x or 24x right now ?
set lowgap to whatever is needed for GPU/system to run. Whatever vista32 shows as available is what you have, with any decent 512MB-1GB GPU card you're looking at only 2-2.5GB available ram on 32bit system and even 64bit unless you move to 6GB ram then you're see between 4.5-5+ GB available.
Nope still going strong here :)
Something happened to yours ?
I have used RAID-mode on DFI's stock controller (Intel ICH10), for Vertex 30GB as W7 OS-disk, and all my tests confirms that it is performing much better than IDE-mode.
I could install W7 out of box (without loading disk drivers), but have installed Intel Matrix Storage Manager on W7 later.
