I just got my Q6600 to 3.9GHz :D
http://i292.photobucket.com/albums/m...Overclock1.jpg
http://i292.photobucket.com/albums/m...Overclock2.jpg
I almost got 4.1GHz, but it was 2 hot today 2 push the volts any higher :(.
here is my new giga UD3R bios F4 with my 24/7 Settings i have now v-core 1,27V amd its game and prime stabil.
i have before a asus p5Q-E and its not stabil.
http://www.abload.de/thumb/490x854165ghztl38.jpg
i run both 4.4 & 4.5 for one hour prime (i was in a hurry, will test longer soon) and alot of benching also play FC2 for 3hrs on 4.5GHz:D, on 4.6 id ENABLE Load-Line Calibration because of random freezing, seem to fix it, have not run prime for more than 15min, will hopfully test it latter,
i did get to 4.7GHz
http://valid.canardpc.com/show_oc.php?id=465080
working on 4.8 right now:up: crashed just before a validate it:down:
nice job fatguy on the 3.9GHz with 1.44v:up: i had to run 1.65 for that and 1.76v for 4.1 with my Q6600
How do i disable cores? I want to see how high it will go on 2 cores and 1 core.
Official BIOS on Giga site:
GA-EP45-UD3R - F5
GA-EP45-UD3P - F6
GA-EP45-UD3LR - F4
F6 has come a bit late, I was hoping we would have a F7 final (UD3P) for Christmas beings F7a has been doing the rounds for a bit now.
Thanks for posting links.
How do I unlock extra BIOS options? I heard it was ctrl + F1. But I do that and the screen like refreashs and nothing changes?
BuGjAE and radaja,
on your posted earlier (#794/95/96), you're welcome and thanks.
fatguy1992,it doesnt have this feature anymore, although if you go to the page where you set the boot order,i think its called advanced something,and then do the ctrl+f1 you do see some kind of change not sure what it is but something extra get added there.
Ok guy I think there are something improvement with F6 here is the quick test result.
Hi there guys, had a ud3p for about a week now trying to push my q9550 past 4ghz. right now its stable at 465*8.5 but if i move it up to 470 I am getting system freezes after about 5 mins. The thing that confuses me is that up until it freezes there are no calculation errors in linpack/prime95/etc. Extra voltage on mch or core don't seem to help. I know my ram is good to around 1020 or so on these timings/volts.
I'm really here to ask what would cause freezing like this? What can I do to prevent it? Hopefully some of you with more experience than I will know.
These settings here are not voltage optimised but they are fairly stable from initial testing. I could probably put together a bios template tomorrow when I have the time if you think it would help.
Hi i just got this board with an e8400. My problem is i cant boot with all 4 ram slots used. I can only boot with 2 slots. Im pissed off because i already ordered 4x2gb g skills 8500. Is this a common problem? Any ideas?
You need higher MCH with more memory as well as faster FSB's. For my 2x2GB I need 1.34v for 420FSB, then more with more FSB to ~1.4v MCH
Itīs a sensetive board this EP-45-UD3P, I have a hard time get this setup stable with my E8400 C0 and 2x1 Kingston HyperX PC9600.
450 9 4050 1200 555 15 tRD7 Turbo
I can run 50 loop LinX with 57% MCH ref and itīs stable but with Orthos blend it error after ~3min and with HCI memtest error after ~100%, Run 50 loop Harbor Assault with Crysis Benchmark Tool and it was okey with 57% MCH ref.
If I try any higher MCH ref then 57% LinX error with in 10min.
I try MCH ref 60% and Orthos blend have been running for 30min and is still running.
CPU Term lower then 1,28 LinX error within 30min.
If I run MCH higher then 1,48 LinX error within 10min and lower then 1,46 error within 20min.
I have Thermalright HR-05 SLI/IFX with a 80mm fan for the HCM so heat shouldnīt be a problem.
Sometimes when I restart it even boot up it just loop in keep booting or 2 or 3 reboots then all fans on but screen is black and I have to shut it down and restart and it starts with default BIOS setup (o man, itīs so annoying :down:, never happens with any of my Asus board).
Any suggestings? :shrug:
PHP Code:GIGABYTE GA-EP45-UD3P BIOS F4 E8400 2x1 Kingston HyperX PC9600 1200 555 15 tRD7 Turbo
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..................: Auto
CPU Clock Ratio ..........................: 9
Fine CPU Clock Ratio......................: 0
CPU Frequency ............................: 4.05GHz (450x9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control....................: Enabled
CPU Host Frequency (Mhz) .................: 450
PCI Express Frequency (Mhz) ..............: 100
C.I.A. 2..................................: Disabled
Advanced Clock Control
CPU Clock Drive...........................: 700mv
PCI Express Clock Drive...................: 700mv
CPU Clock Skew (ps).......................: 0ps
MCH Clock Skew (ps).......................: 0ps
DRAM Performance Control
Performance Enhance......................: Turbo
MCH Frequency Latch......................: 200MHz
System Memory Multiplier ................: 2.66C
Memory Frequency (Mhz) ..................: 1200
DRAM Timing Selectable ..................: Manual
Standard Timing Control
CAS Latency Time.........................: 5
tRCD ....................................: 5
tRP......................................: 5
tRAS.....................................: 15
Advanced Timing Control [Press Enter]
tRRD.....................................: 3 [Auto]
tWTR.....................................: 3 [Auto]
tWR......................................: 6 [Auto]
tRFC.....................................: 42 [Auto]
tRTP.....................................: 3 [Auto]
Command Rate (CMD) ......................: 0 [Auto]
Channel A
Channel A Timings Settings
Static tRead Value......................: 7
Channel B
Channel B Timings Settings
Motherboard Voltage Control
Load-Line Calibration.....................: Disabled
CPU Vcore...............1.22500V..........: 1.42500
CPU Termination.........1.200V............: 1.280
CPU PLL.................1.500V............: 1.500
CPU Reference...........0.760V............: 0,810 (63,5%)
MCH/ICH
MCH Core................1.100V............: 1.480
MCH Reference...........0.760V............: 0,730 (57%)
MCH/DRAM Reference......0.900V............: Auto
ICH I/O.................1.500V............: 1,500
ICH Core................1.100V............: 1,100
DRAM
DRAM Voltage............1.800V............: 2,300
DRAM Termination........0.900V............: Auto
Channel A Address Vref..0.900V............: Auto
Channel B Address Vref..0.900V............: Auto
Advanced Settings
Limit CPUID Max. to 3.....................: Disabled
No-Execute Memory Protect.................: Enabled
CPU Enhanced Halt (C1E)...................: Disabled
C2/C2E State Support......................: Disabled
x C4/C4E State Support....................: Disabled
CPU Thermal Monitor 2(TM2) ...............: Enabled
CPU EIST Function.........................: Disabled
Virtualization Technology.................: Disabled
New guy here. Just got a UD3P and I must say I am impressed.
http://valid.canardpc.com/show_oc.php?id=466570
http://valid.canardpc.com/show_oc.php?id=466169
The best I was able to reach with the same chip using my old P35-DS3P was 3.7G and 463FSB.
Fatguy1992, thank you for sharing your settings. It was very helpful. BTW, which BIOS are you using?
Did you Try MCH reference lower, like .64(50% according to your 1.28 VTT)-.70v(54.7%) this seems to be the range that many have success with. For me .66 is the ticket, others like .68 or .70v. These are what ET6 reports or set them w/ CPU termination set at 1.2. You can raise the VTT after that back to your 1.28
Also on the "CPU clock drive" try 800mv, then on "PCI express clock drive" try 900mv
Also you can try CPU clock skew like 200ps
Thank you
When I try MCH 50% - 55% it donīt boot and if I try with CPU clock drive try 800mv, PCI express clock drive 900mv and CPU clock skew 200ps the same.
If I run CPU, PCI clock drive at default, CPU, MCH clock skew 0ps and MCH ref 61,5% (CPU Term 1,28, MCH ref 0,79) I can run Orthos blend for 5hrs (I stopped it) and HCI memtest 1000%, seems okey but if I restart it boot back to default BIOS setup, shall try to increase CPU PLL from 1,50 to 1,57 to see if boots okey.
Do you think that tRD7 are to low for the P45 chipset, with my Rampage Formula (X48) I could run tRD6 with FSB 450 1200 CAS5.
Well, I got my MB back from rma lastnight.I have been playing with it some. I have my 7200 up to 3.8 and thats pretty good but i have lost me sound once it upped the clock from 3.5 to 3.8. Its a pci-e card and i have it set to 99. Has anyone ran into this? O, my dvd cant even run sound.:shocked:
well,I'm running @ 4.0 and running prime:up::shocked::shocked: still no sound tho
