Yes it is. My CPU's temps are around 53-55C at full load. 3.2GHz@1.35V
Hey this is really hot, how do you read the MB temps?
I'm using asus probe2 and i' having around 31°C at full load with intelburntest using maximum ram.
What voltages have you set?
I'm using
HT voltage: 1.34
NB (core) voltage: 1.3
I've come a little further with my AMD system, i'm aiming for a 100% stable 24/7 overclock, because this system ist mainly my storage server with software raid and encryption.
here is a result with a uncommon CPU for this board ;)
http://img168.imageshack.us/img168/5...0mhzqx5.th.jpg
junkY
i use aod to read out the mb temps. but i also have a thermal sensor of my zalman zm-mfc2 attached to the fins of the heatpipe cooler. that sensor reads 65°C under full load. thatīs only the cooler fins, so maybe the whole mosfet and nb are getting a little hotter.
the voltages for ht and nbcore are at stock. cpu is at 1.4v+2%acc at 3.2ghz.
i can easily put my fingers on every peace of copper (mosfet,nb,sb) on that mainboard, and it's rather cool.
there are 2 possibilities:
1. your phenom is stressing the mosfets/northbridge much more than my x2 5050e or
2. your board is not ok
have you got annother cpu which you test the board with?
and btw, whar are your ambient temps and which case are you using?
mine are about 20-22°C and the board is in a sharkoon rebel 12 with a 25cm fan blowing at it.
Hi guys, I've decided this is the board for me, but can someone please explain the 1066 memory thing?
I've read that the Phenom can only handle 1066 memory in 1 stick per channel? So does that mean we have to run our mem in single channel mode? Or drop to 800 in dual channel?
Sorry if this is a stupid question, or has already been discussed, I'm just a little confused?
What benefit does dual channel give? And would 1066 single channel be better than 800 dual channel?
You sure the heatsink is seated right? Maybe the thermal compound not applied correctly? When I got the new board that I tried it without taking off the AM2 retention bracket I tried it on air and with my 9950 @ 3.2 GHz @ 1.4v I saw about 55šc full load with the factory Heatsink.
Couple of questions
1- What is more or less your ambient temp?
2- what are you using to monitor temps?
3- What were your load temps before the TRUE?
hi there Darxide, welcome to XS.
you can run 1066 in dual channel. You just have to make sure to go into the BIOS and set your memory frequency to 1066. Yes 1066 would be better than 800. The 1066 RAM is already manufactured to run at 1066, so you can set it at 800 in the BIOS and then you can raise your FSB and not have to worry if you are pushing the RAM while raising the FSB, or you can leave it at 1066 and try to clock the memory even higher.
phenom can run two 1066mhz it's 2gbs sticks put more stress on the IMC. 9 I haven't seen many running 8gbs yet.
in ganged mode it runs in one 128bit dual channel and unganged it runs two 64 bit channels.
there difference is in mutli-thread programs and single threaded programs
Yeah, but it's still much better than you. As we see you are not stable even in the winter at all. :D
I'm sure and I use AC MX-2 tc. The ambeint is around 25C. I use Everest for monitorting. It can show the core temp.
I can't remember my load temps before the TRUE because that was more than a year ago with different board and CPU.
Overall I'm pleased with the temps because I have a relative slow fan on the heatsink.
you can run dual 128 in both ganged and unganged On this bored. I couldn't on the K9A2 Plat board before I sold it tho. But all my other boards allow me to. As long as the DIMMs are in the right slots.
(Ganged)
http://3800z24.info/Phenom/9950/Dual...3.3g_32bit.JPG
(UnGanged)
http://3800z24.info/Phenom/9950/3.3ghz_dual_unGang.JPG
well.. i hope that my phenom is stressing the mosfets a little more than ur x2.. at least itīs a 140watter.
i donīt have another cpu to test with. why should i test? itīs working properly if i donīt stress it too much, 3.4ghz@1.6v is really stressing it.
ambient temp is around 23-25°C and my case is a chieftech mesh big tower with a 3x120mm radiator in the top and one 120mm fan at the back under the powersupply. if i had a 250mm fan blowing at my board i bet it wouldnīt get hot. but iīm on water so i donīt have a really good airflow over the board.
what board and ram evilsurge?
c'mon guys,
I want to see some phenom II teasers with the M3A79-T :p:
I just ordered this Mobo for a Phenom II. :D
Hope it handles good, and I hope they don't bring out new AM2+ boards :(
Hey, thanks.
I was gonna get a Phenom 9950, but I've now decided to wait for the Phenom II, so I've bought a cheap Athlon X2 4000+ from eBay, just to get up and running. That way I can make sure the BIOS is flashed to the latest version for Phenom II.
Still havn't bought any RAM though......suggestions?
I was thinking about this stuf
http://www.geil.com.tw/products/showSpec/id/118
Mushkin Black Ascent 1006 is superb ram.
http://www.kmelektronik.de/
Not expensive either.
Has any of you guys had an issue with the board not posting and crash recovery not working?
Everytime I raise HT above 2000 the board will not post and i have to clear cmos.
IT's pissing me off that i cant overclock the HT without it not posting and i have to take out my 3870X2 everytime to reset cmos.
