Soo.... what good is 16GB of RAM if you only have 32 bit?
Makes for a bigger e-p33n.
1GB in mine :rolleyes:
Running Vista Ultimate, it's uptime is nearly 5 months if you take 2 reboots out of account. I never knew it was that good with low amounts of RAM :p:
IIRC, Server 2k3 and Server 2k8 can both utilize very high amounts of RAM on x86-based systems.
Oh darn it old man now i started to look for Quad socket 603 board and well those chips are cheaps as nothing, which is good thing :rofl:
Well here's some data about which 32bit os's can utilize more than 4GB of ram :)
http://www.microsoft.com/whdc/system...AE/PAEdrv.mspx
I see.. I only know PAE from Asus mobos, helps you utilize a little bit more of your 4GB of Ram in good old XP 32 ;)
Still, I'll leave my Sammy running with 2x1GB. It's more than it needs anyway, 1GB was fine too, I just wanted dual channel on principle :D
Anything that wants or needs a lot of ram runs on the harpers o the i7 anyway, like hd video encoding and stuff (4GB per process wouldnt be enough here anyways without the program splitting it up more intelligently than it currently does...)
so to utilize the right amount of memory-what is the most ideal OS
Tried taking that ground wire to the back of the board to ground on the 8 pin.. Same..:(
Took wire to back of board and tied it into the 3.3v line and it booted and is running but at stock 2000mhz..
I tried?:shrug:
Well at least you still have a working board.
Oddly enough ... if you kill it, it may not work.
