Ave,
Alright, attempted some OC'ing and right off the bat, the P45's stability is mind blowing. I hit a wall @ 360 with my old E6420/P5W setup - but on this P5Q/Q9450, even at stock volts i'm pushing the FSB without any stability issues whatsoever. And i'm on Air (AC7).
Got a 100% OC: 3.6Ghz (450 X 8) / DDR2-901 (1:1)
6 hrs Prime95 (Small FFT's) Stable & OCCT 2hrs Stable with pretty much all stock volts (including RAM) & 1.325v CPU ...
http://b3lial.rahulsjohari.com/GRAPH...0X8_062208.gif
The only thing i'm concerned about right now is temperatures. Idle around 40 is fine, but during Prime95 (small fft's) after an hour into 100% on all four cores, temperatures were starting to hover around
65 - 70 as reported by Real Temp. Should I be concerned? Also, is there anything under BIOS I can change to lower temperatures?
My Settings:
JumperFree Configuration Settings
AI Overclock tuner: Manual
CPU Ratio Setting: 8.0
FSB Strap to North Bridge: AUTO
FSB Frequency: 450
PCI-E Frequency: 101
DRAM Frequency: DDR2-901 (1:1)
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 18
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Static Read Control: DISABLED
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
Common Performance Level [12]
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.325v
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.5v
FSB Termination Voltage: 1.28v
DRAM Voltage: 1.96v
NB Voltage: 1.20v
NB GTL Reference: AUTO
SBridge Voltage: 1.10v
PCIE SATA Voltage: 1.50v
Load Line Calibration: ENABLED
CPU Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
Advance CPU Settings
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
