God dam Tyke, can I have some seeds from your dollar trees? :D
What numbers do you get running HD Tune or HDTach? I have 2 VR in Raid0 but they suck in my 780i. A week ago, when I used them on my DFI LT X48, I got a burst speed of 460MB/s. Now I get 390MB/s. The result in HD Tune is even worse.
Thank you for the reply.
I have just ordered an Adaptec 5405 Raid Controller (with 256MB of onboard cache and a 1.2GHz dual core processor!!!), so I will post the figures I get with that later in the week. Look at the improvement MaximumPC got with four Raptors in Raid using this card!
http://www.maximumpc.com/sites/futur...chmarksBIG.gif
These HDTach results are using the long test, the short test gives 172MB/s average read, 340MB/s burst and 7.2ms random access.
Thats a good speed (well, not really into HDD performance, but it seems pretty high for me)
These are a lot faster than the raptors, and massively cooler and quieter! When I get the raid card tomorrow I will redo the benchmark!
Have you tried the 0801 bios yet, I can run 1800/2000 unlinked for the first time with it. However it is not quite stable at the settings I had on 0704, back to those GTLS!!!
Im going to run that app to see how fast my raptors run :) I would also love to try one of those VRaptors, but $300 is out of budget for me :(
Im on 0801, booted and surfing the web right now. Will leave it priming at night. Im also going to see if this BIOS fixed my SLI issues.
Overclockes better? Will check that as soon as I finish with the SLI stuff :)
EDIT: Im so annoyed that I still have the SLI issue that I dont have any reason to keep pushing my cpu/ram. Will wait for a BIOs that fixes SLI issues first, then keep pushing system.
so which boards is mainly free of corruption trouble?
Well yeah if you want to be 100% free of corruption go Intel or AMD
And just to answer your question, SIIE is fixed with 0704 and eVGA with P05, however, some people still suffering from corruption. Dont know what to say about that.
let's stick to some factual information...i've sifted through a few pages and it certainly doesn't look as bad as you are making it out to be :shrug:
i bet that ppl that are having real issues are in minority now
also if i experienced issues in the past i would use a completely different hard drive to check now
i have been honest and upfront about my corruption from the get go and i definitely put my board aside as i just could not bother any more...........
with P05 i have now also purposefully tried booting with completely unstable settings to try and corrupt my OS without luck.....OS still loads when i back down a little
:shrug:
Well for some reason, everytime I go and check I see people complaining about corruption still not fixed.
I dont know, they are probably doing something wrong because as you said, is not about just updating BIOS, but to do a fresh installation of OS too and format the drive just to make sure.
I also tried hard settings, windows wouldnt load or I would freeze in BIOS screen but never corrupted my system which makes me think that people are too lazy to start from the beggining. If you are experiencing corruption
1) format the drive
2) fresh install of OS
3) if 1 & 2 didnt work, OC from scratch
Slim, fresh installs of OS itīs what iīve been doing almost daily in this DAMN board!!!!:mad:
I STILL HAVE CORRUPTION with BIOS 0704 and 0801 when i run memory LINKED AND SINKED...
And itīs not the RAPTORīs, iīve been instaling the OS on my SEAGATEīs and have the very same problem.
When i mean CORRUPTION, i mean it fails the SFC test, the OS boots ok but it always fails the SFC test, iīve tried raising voltages in NB and SB, but made no diference.
A keep having windows dreamscenes artifacts with BIOS 0701,0702,0703,0704 and 0801 but not with 0603. This artifacts grow in number when the computer is doing memory intensive tasks. For example if i run everest ,and run the memory benchmark i see artifacts all over the screen.... :(
With BIOS 0603 i play Crysis for hours without any glitch, with later BIOS is just stops working after 1 or 2 minutes with the driver as stopped worked and was recovered...
Hello guys
I've been using the EVGA 790i SLI board for about 3 weeks. I wasn't aware of this corruption issue and tried with the shipping P03 bios first and corrupted my windows setup 3 times in 2 days. Then I found out about it and upgraded my Bios to P05. Even so it didn't solve all the problems but it sure helped the issue a lot. After the flash procedure I had corruption two more times in 2 weeks. And for now it seems to be stable for about a week or so. My setup is like this :
Evga 790i
Intel QX9650 and E8500 (sometimes)
2x1GB Super Talent 2000 MHz (9-9-9-26)
512 MB Zotac 9600GT AMP
WD Raptor 150 GB
Silverstone 850 Watt PSU
I am now using my E8500 cpu at 5200 mhz - 9.5x547 with vapochill. My ram are working in unlinked mode at 1790 MHz 8-7-6-20 at 2.0 volts. My vcore is 1.70 volts and SPP voltage is 1.45 volts. The others are set to auto. I am afraid to stress my sticks and try higher frequencies with CL7 timings because whenever I do it the windows setup can get corruptted after a numerous number of unsuccessful boot trials. You can say that it's bc of my trials but normally I didn't get this kind of behavior from other Intel chipsets.
I am now using the above settings and everything seems to be ok for a week like I said but the issue is not %100 solved. I just want to point out that P05 can still make these issues.
Silverstone
Maybe you should ask M@G!C for his settings because he is living a nightmare.
I understand how you feel. I hate to take 20 mins to install the OS and all that crap.
Benchz said SFC should not be used as a source to indicate corruption. He mentioned long ago he got error with another board (x48 I believe).
Have you tried stock settings and see if you get those artifacts? Are you sure your sticks are 100% working? Maybe a defective video card?
The artifacts only happen if i run 1800Mhz on memory even unlinked and unsynked. If i run memory at 1600Mhz no problem at all. My sticks are 100%.
