Originally Posted by GAM
btw, I experienced the same problem with DQ6. I didn't need to wait at all though. Most reboots from Windows would require re-enabling OC settings, yet, reboot from BIOS were usually fine (unless I was playing/testing settings). Statement valid to F4a. RMA'd due to MB failure after that. (Thinking about it now, there is probably a connection between the reset cycle that I couldn't overcome and the resetting of OC settings on controlled reboot. :rolleyes: )
From memory, this occurred mostly with OC's of 400fsb and above.
I am also fairly sure but not positive that I could successfully boot to Windows @450+, but not stable.
