Originally Posted by
Kiwi76
Now this is interesting. Under Orthos loads, (one of) my CPU core goes up to 65C even in Everest with the default TjMax of 100C, which Intel states (although there are compelling arguments it may be 95C). The CPU itself sometimes goes up to just under 65C, and the other core tops out around 60C. This is at 4.05GHz. At 4.275GHz, add ~5C to each.
I've long expected my CPU to be running much cooler than it's being reported as. I've lapped it, switched from a Freezer 7 Pro to a Xigmatech HDT s1283 (yes, I applied thermal paste correctly), and have great case airflow (Stacker 830SE with many fans). All of these efforts gave minimal or no improvement in temperatures, yet, the sensors aren't stuck. If I overclock, they go up, and if I underclock, they go way down. I simply think the CPU itself or motherboard sensors are way off.
I also think this because I always see others saying they have the same CPU with an weaker cooler, a non-lapped CPU, and comparable case cooling, and they get idle temperatures in the 20s, and loads under Orthos for the cores no higher than 45C. How, then, is mine running that much warmer, or is it really?
Get this. With the temperatures you listed above, you say it's too hot to touch. I can touch the base of the heatpipes on the cooler, and remember, the heatpipes are HDT touching the CPU itself, and I can not only hold my finger there at these supposed 65C+ (70C at 4.2GHz wasn't much warmer) temperatures, but it's barely even warm. My Northbriudge, by contrast, typically runs ~45C, and the heatpipe between it and the Soutbridge is much warmer, almost too hot to keep a touch on, but not quite.
Would I be safe then, to assume I can basically "ignore temperatures" and push it further? I got my E8400 the day after launch (January 21st was the first day Newegg had them in), and the batch number is in the signature in case it matters, and I remember these early ones had temperature issues. I'm thinking I got either I got one of them, or the motherboard just has really sensitive sensors.
