You might want to try giving a new BIOS a shot. That can definately fix overclocking errors like you described. 1.36b seems to be a very good one, take a look at it.
As for the 6800, I can't help ya there. :(
Silly did you read the first post of this topic?
Several usefull tips there :)
Did you disable Aggresive Timings?
What serialnumber is your mobo?
And you can always try some other drivers for the vga,
maybe that'll help :)
I have PC4800 TCCD. Problem is that I can only boot my computer at 300fsb, with one memory installed, if i try 2 memorys it won´t boot.
The motherboard is instable at 280fsb with 2 momorys installed.
Have tried several different timings, voltage and so on.
Try sticking that ram in the first 2 slots closest to the cpu. They are different colors, one green one purple... It should boot. :) and be dual channel ;)Quote:
Originally Posted by Razzz
I know, have tried that, it will boot at 290x9 extremly instable. With one memory stick I´II be able to run 3dMark. Strange.Quote:
Originally Posted by mike.elmes
Perhaps buy Abits motherboard instead.
OK got the noob ? of the day.....
2 Sticks of Corsair Value Select 512MB each
My memory is running at 220, 2.5,3,3,8 T1
What the hell is 1:1 ? I dont see that option but every one talks about it :stick:
Bad with my bh6´s
I can run at 1T only around 210mhz and around 240 2T with booster 3,4-3,7v. Tried bios 1.36 and 1.37 but cant pass this, any Tips?...
1:1 means running synchronous
RAM fequency:fsb frequency
example: RAM=200Mhz (DDR400) : fsb=200Mhz
is what people call 1:1
(ASUS makes is more correct and more difficult to understand as they call it in their bios 2:1, DDR400:fsb200)
ClockGen doesn't work with the MSI ?
http://www.cpuid.com/download/CG-ICS950403.zip
Cant have the clock menu :(
And can i have a link for the 1.3x bios, i cant run my BH at 2/2/2/5 :rolleyes:
So is mine is not running 1:1 then ? and is 1:1 better or just more balance and stable ?Quote:
Originally Posted by OneyedK
1:1 is better because the ram and the procesor work synchronous
Wrong application, thats for the Neo..Quote:
Originally Posted by Jeager
For the Neo2, which is NF3 you need this one:
http://www.cpuid.com/download/CG-NVNF3.zip
HTH
m
What pci slots do you use that do not share an IRQ..Looks like slot 2 and 5 share an IRQ
I have an Audigy2 and an Adaptec 2906 scsi card for scanner...I was going to put them in slot 2 & 3...leave abit more circ around my agp card and make it easier to get to the CMOS jumpers
Ya what is the best slot for Audigy 2 as I to would like to know....Quote:
Sorry I missed this..
Here is a page with ALL the bios's on it:
http://www.lejabeach.com/MSIK8N/k8nneo2.html
GL
m
Here is a page with ALL the bios's for NEO2 (this is a Neo2 thread) on it:
Look at 1.36b(check this one first, ya may not need 1.41) and 1.41mod
GL
m
Originally Posted by SillySider03
Perhaps the problem lies in using VS RAM. I mean it does ( PC3200 ) 200 mHZ, it does 210, it does 220, but perhaps it just doesn't have what it takes to do over that. I'm not saying that is the case, but perhaps it is. If you were using TCCD, or some other RAM , I'd assume you could get higher.
From your experience, by how much the K8N Neo2 undervolt? Does it change from BIOS to BIOS? Also, I want to know which value I should put in "AGP Aparture Size", my card is 6800GT and currently it's 256MB.
Thanks! :D
mine under volts BAD!!! at 1.55v and 5.0% over vid i get a mere 1.552v?? im going to try diff bioses but i dont expect it to help much right now im using the 1.41 bios...
peace perc,
Neo2 do not undervolts! The max. settings u can use in Bios is 1,475 + x%!
Anything higher then 1,475V do not work, and switch back to the 1,475V!
As for ur example : 1,475 + 5% = 1,548V
Under load the Neo2 even overvolt a bit! Idle 1,600V Load 1,616V , for
example.
Originally Posted by GravediggA
no man i it undervolts big time! when i set it to 1.55v 8.0% over vid i can get it up to 1.6v but thats it. even in the bios it reads 1.6v when set to the following settings. it undervolts man trust me.... ill go try what you saying but im not holding my breath.
peace perc,
HEEELLLOOOOO! :rolleyes:
1,475V is the max.! Nothing above that will work! If u set it to 1,55V it is
even 1,475!
U got what i mean? :)
dude dont treat me like a noob the max is NOT 1.45v so chill the :banana::banana::banana::banana: out man. my bios shows it working and it is under volting so back off...
perc,
Ok, if u won't believe me, it's not my problem m8! :)
Watch your language, Perc.Quote:
Originally Posted by Perc
