:D
http://img231.imageshack.us/img231/1658/dsc00464dv3.jpg
Tommy_Hewitt, you have a beautiful system there. it's just Thermalright set :).
but totally wasst of money the memorycoolers. But it looks nice
You cant use those mem coolers with 4gbs can you?
This is my very untidy case (specs in sig) ... i was re-seating my Heatsink yesterday and noticed that the northbridge heatsink wasnt sitting flat :eek: so i replaced it with a HR-05-SLi that i had on my desk :D also replaced all the thermal pads on the mofsets etc
http://img103.imagevenue.com/loc184/..._122_184lo.jpg
ignore the crappy carpet / socks / shorts ;)
my little gfxcooling collection: :toast:
x800 pro @ xt-pe:
http://img356.imageshack.us/img356/4...proxtpecu5.jpg
6800 ultra:
http://img155.imageshack.us/img155/488/6800ultrabp8.jpg
7800 gtx:
http://img155.imageshack.us/img155/4432/7800gtxux3.jpg
My P1 PhysX cooling mod:
http://img132.imageshack.us/img132/1...5650pixqn7.jpg Running near silent @ 6V :toast:
Nice photo but u should clean the dust :p:
@Tommy_Hewitt, all that's missing are the HR-05 SLi for the SB, and the Ultra-120 Extreme for the proc...
Hello, New member here. Got tired of Coolant Leaking after a meltdown. Went Passive.
http://www.xtremesystems.org/forums/...&postcount=749
http://www.msprotege.com/members/Brian%20MP5T/1.jpg
http://www.msprotege.com/members/Brian%20MP5T/2.jpg
I think, that's not a good idea, cause then there would be no fan, which brings the hot air out of the case
:D, thx
thx, but the dust ist a not a big problem for me. ;)
my x1900 xtx:
http://img370.imageshack.us/img370/3109/img4788iw0.jpg
My good old Infinity :D
http://img462.imageshack.us/img462/4120/dsc00477po3.jpg
So I installed two chip set coolers from thermaltake. WOW.
Dropped from 80 deg to 54.
The fans are controlled by the BIOS and are quiet.
The P5n-32 SLI 680i Runs very hot on the NB and SB. Wanted to fix the problem. This is an overkill solution!
http://www.msprotege.com/members/Brian%20MP5T/8.jpg
http://www.msprotege.com/members/Brian%20MP5T/9.jpg
http://www.msprotege.com/members/Brian%20MP5T/10.jpg
http://www.msprotege.com/members/Brian%20MP5T/11.jpg
http://www.msprotege.com/members/Brian%20MP5T/12.jpg
http://www.msprotege.com/members/Brian%20MP5T/13.jpg
Awesome!
Brian: you're saying that your MB is a p5n32 then why does your MB have striker extreme printed on the PCB??
