Hi Handyman! from what i have read its IOH PCIE Voltage. Anyone confirm this?
what kind of BSOD you get, if its 0x00000116, then its the IOH Core....
I have now a working Xfire setup and I can run both HD 5850 with 1.19v IOH COre Voltage (No overclock GPU)
But for heavy overclocking...I was able to run without error at 1.25 v IOH Core
My PCIE IOH Voltage is raised by 2 bumps at 1.53v
i just ran my980x at 1.375 at 4.2 ghz prime95 temps where hitting like 75 scary had to back down plus ioh was hitting nearly 70 to
Ooohhh, thats a little bit high.
My i7 930 is at 4,3 Ghz and Im using Linx to stress test (70'C)
But Now I've add my second HD 5850 to my setup, but can someone tell me why I lost 3 G-Flops (from 55 to 52 G Flops) while Linx Stress
Is that normal...even with much Higher Vcore I get the same GFlops
Hey guys I currently own a x58 evga classified mb 3 way an was thinkig about buying the rampage 3 mb .. How is it so far for ocing the board and what about tempson the board? Worth it for me to buy this or just keep my board I have now? I'm digging the future proof 3.0 USB connects and a few other goodies the rampage has to offer.
whats the highest temp u can go on these 980chips
honest answer, it will throttle when its too hot ;)
I usually dont like to be stressing much past mid 80c's for 24/7 use though.
I was using 602 for over 6ghz.. I think it's pretty good! Has anyone else tested 602 and LN2? Is there a better one..
I know that 704 has more options for LN2
I replaced the heatsink with the Active fan one and ICH / IOH temps are 61 C - 62 C idle , still high but better than before
Room temp is 26 C (With AC)
It is now OCed to 4.22Ghz CPU but RAM is at 1611 CL7
I can NOT get it to 2000 CL9 and that happened before with a friend's Asus P6T
Is there any compatibility issue between OCZ Blade 2000 CL9 and Asus mobos ? :confused:
I need BIOS settings for the Core i7 920 and OCZ Blade 2000 CL9
I have another observasion :
With my Gigabyte EX58-EXTREME and OCZ Vertex 2 50GB SSD, Windows 7 Boot with blazingly fast , but with Asus R3E it takes alot on the "Welcome" screen before logging into Windows :confused:
Thanks in advance
I will try 3N but it worked fine with Gigabyte with 1N !
Nope
Even at stock speeds it takes much, much longer for Windows 7 booting (With Gigabyte I was not even seeing the Welcome screen but with Asus R3E it takes about 20-30 seconds !!!)
I've tried QPI Voltage up to 1.6v and still no post (Gigabyte worked just fine at 1.555v VTT)
I've noticed Asus boards in general seem to boot slow into Windows. I figured out on my P5K if I disabled the onboard audio it would boot quite a bit faster. wonder if that's the case with the RIII.
Could the people with the motherboard blocks please get them installed and show us some pictures :p:. I am thinking of getting one but I am also undecided on which version to get (plexi/acetel).
I'll have a pic next week, Im just waiting for a couple of fittings.
I choose plexi because I have both of my GPU blocks in plexi..the plexi is damm good quality
Thanks dude, your setup does indeed look pretty sweet atm. My one will look quite simalar when I am finished, 800D, all black apache fans, tygon tubing, red fluid, black braid, you get the idea haha. Will also post some picutres when I am finish, I too am awaiting fittings. I still haven't upgraded both my graphics card (GTX 280) and haven't got myself an SSD yet :(.
to better contacts...
