Still testing volts, but here is my D0 from Microcenter.
3849A866
http://i29.tinypic.com/inwd4y.jpg
4Ghz @ 1.3v however i'm still testing to see if I can go lower
3849A866
I got a C0 Batch# 3838B556 anyone know where it can go up to? im using a UD5 and rest is in my Sig.
Guys how good is this D0 batch:
3847B022
Just got my 920
SLBEJ
3910A418
See what it'll do later tonight.
scotti, I just got two of those processors, same exact numbers. Let me know how yours OC. Mine is going to be water cooled and the wifes will be on air.
Here its my results :)
Is not one of the best, but i will try get better clocks for now.
Core i7 920 @ 4200mhz / Vcore at 1.243 on load :D
When i make this test a was using the True 120, now i put a nice WaterCooler in here :cool: hehehe
http://img406.imageshack.us/img406/2...rei7920420.png
But the way...some one knows what the best bbclok i can get on P6T DLX V2?
hello,
i just got a 3908A407, im now doin prime 4.4ghz @ 1.4v
is that any good?
Batch #3849A769 4.2Ghz 1.23v load.
http://i552.photobucket.com/albums/j...2Ghzstable.jpg
this is going to be my 24/7 overclock
http://img23.imageshack.us/img23/2449/img0407pmi.jpg
http://img11.imageshack.us/img11/4020/78562572.jpg
hey,
so I tested my new D0 batch 3851A286
went up to 4,629GHz! on a foxconn bloodrage (p07 bios)
Still have to try different settings to see how far I can stabilise it. But it seemed ok until 4,3!
For sure 3,990GHZ stable with less than 1,3V
http://teamdlp.free.fr/pc/super%20pi.jpg
Nice CPU i7 975 :p:
Pseudo : HornetCup
Batch : 3945B239
OC CPU: 4600 mhz
vCore : 1.45
vQPI : 1.34
vPLL : 1.80
Mainboard : Asus P6T6 WS Revolution
cooling : WC 2rads 240+360
Temp : 19° C
Screen :
http://nsa08.casimages.com/img/2009/...3518472237.jpg
http://nsa07.casimages.com/img/2009/...3926139830.png
http://nsa08.casimages.com/img/2009/...3809559412.png
Did you get yours from the microcenter in westmont?
I have the exact same batch number - I saw two batches while I was there, 3844A717 (they had several) and 3849A866. I did a quick google search while I was there and the latter pulled up better results. Some claimed to do 3.8 on 1.1x, some 4.2 on 1.2x
let me know how yours turns out.
I'm considering going to the other MC to check out the batches there.
very nice hornetcup (green with envy) only joking m8 :)
Very nice Overclocking.
But... does someone has a D0 with the batch 3849Bxxx??
Anyone get their SLBEJ 3910A418 overclocked yet?
Do matching batches mean anything? I've seen pep with the same batch as mine (3850A975) with OCs in the 4GHz - 4.2GHz with 1.25/1.27v area and mine needing 1.32 for 4GHz and a whopping 1.4v for 4.2GHz
And maybe I just have a turd of a D0
Batches often let you know if its decent but obs some may be worse than others. Have you tried messing with the other settings to try lower the vcore?
