:cool: Which option, where?Quote:
So no bios updates yet??
Thanks for your comment.Quote:
I don´t think i have an option in my BIOS that really does that, what´s it called? I have a 480W power supply, i recon that should be enough. Haven´t had any other fluctuations except for the booting problem.
I'm so sorry, I'm remembering the setting from my previous board (DFI SLI-DR). Anyway, it sounds like you need to boost your vcore - unfortunately you can't do it temporarily.
Originally Posted by WackyWookie
it doesnt matter if its a 1000w psu if its crap psu then your s.o.l.
So, no bios update for the DQ6 yet?
Mel
Nope, however,the letters from Gigabyte consisting of "HAHAH SUCKERS!" are on thier way to all registered DQ6 owners
yeah you DQ6 owners sure are getting the ol finger from gigabyte
id sell it, take the loss, and go get a different board.
What letters?
huh?
it was a joke dude
Man....don't scare me like that!
ANyway I had a GA-1975x dies on me and I got a refund from NewEgg.
Gonna get a P5B deluxe and try that and put my 940D in the DQ6.
Mel
I'm still waiting on Gigabyte to get my DQ6 back from RMA. Apparently they're sitting on it. :confused: Can't see that helping much. Anyway, maybe it's not a corrupt BIOS as suspected :stick:
F5 bios on my DS3 made my PC reboot randomly :| sth is :banana::banana::banana::banana:ed up there :| back to F4 retail...
Did you mean the F5E bios??
Did i see that someone has a bios dated August 31st 2006 for the DQ6?, F4e beta bios??
I asked for a RMA on my DQ6 before the holiday, waiting to hear their answer. I should of gone with, and may yet get, the Asus P5B Deluxe. My main feature I wanted was DTS Connect and Asus does not open advertise that the P5B Deluxe has it, had to look at the manual.Quote:
Originally Posted by GAM
F5C and F5E as well ;/Quote:
Originally Posted by cliffy
Here's the F5g BIOS for the DS3, hope it's useful to somebody...
http://home.wanadoo.nl/d.noorlander/965pds3.f5g
I just found that out last week too, from a kind member on avsforum.com. Damn, I should have gotten the Asus P5B Deluxe too - the DQ6 is crap right now:Quote:
- every 5 reboots or so I cannot get DTS Connect or DD Live to work (I found a workaround that is very very ugly)
- it won't overclock to 400 MHz FSB stably
- loud buzzing inductor coil near the DIMMs
- power cycle when you change memory timings and other settings - can wreck your fan controllers or cause excessive wear-and-tear on other components
- HDMI audio jumpers removed (but the solder points are still there) from shipping versions
Now that the P5B Deluxe has DTS Connect the DQ6 really has no point now - unless you really need the Skype features of the ALC888D audio chip!
Wait a sec - I just saw the world's first 600MHz FSB thread - on a DQ6??!!! I'm shocked, shocked I tell you! :)
changelog?Quote:
http://www.jzelectronic.de/jz2/index.php
says nothing, looks as GB is making new revisions without fixing anything ;)
what is changed in F5G?
Told a guy at gigabyte's about my problem, he said I should try this BIOS version. Looks like it solved my problem with the FSB resetting after a couple of hours of inactivity, but i'm not really sure because I haven't left it off for a very long time yet (like 3 hours or so).
Didn't do anything for me
Like...IS there an F4e bios for the DQ6???????
