im pretty sure you'll like that chip kobalt. i have the same stepping and it does 2.96ghz at 1.4vQuote:
Cant wait for my 165 CCBBE 0610DPMW, should be here yesteraday or today, but lets wait some more time :stick: Hope it will be good overclocker and I will get 2.8Ghz on stock vcore :D
I did that with my CCBBE 0610, I think it scales really well with voltage. So far 2.8 at stock, 2.9 at 1.376v (1.425v in ultra-d, 11/14) and haven't tried 3Ghz, but it looks good for 1.45-1.475v if I keep my temps down. All prime stable too. Currently testing the 2.9 one, been 30 mins.Quote:
Originally Posted by Kashelz
initially took me 1.55 to hit 3.0ghz on my CCBBE. currently working my way up from 2700. i want to wait for my 8pin connector to see if that help any
Lol then i had to had the biggest luck of my life to get a ccb1e 0608mpmw for only 280$.Quote:
Originally Posted by itznfb
http://cgi.ebay.com/AMD-Opteron-165-...QQcmdZViewItem
This is the guy i got my chip from.
865pe
You run your opty at only 2800 for 24/7 ? I run my at 2900 @ 1.4v and works perfectly. Would need more than 1.4v to hit 3ghz, but i would have to make a vcore mod.
thats a killer deal man, you should be happy
Do you know if he´s still selling the same stepping? if so, I´d buy 1 right now.Quote:
Originally Posted by Malkec
Only way to find out is to ask the seller, but he'll probably tell you it's random. I think Malkec just got lucky.
Yup, that´s what I thought, I´ll ask the seller anyway. Thanks for reply ;)
^^ That seller never replied to any of my questions regarding his steppings.
Just testing out my first of my two 0608 MPMW's :)
http://img72.imageshack.us/img72/916...efaultv.th.jpg
It failed at 2817 @ stock after 3 hours. This thing is real hot compared to my :cool: CCBBE. I think I need to upgrade my swirftech water kit.
Devious How did you get two of them?
@ Devious: Same question here, and also If you´re planning to get rid of one of those 0608 MPMW's you know where to send PM ;) let me know if you´re planning to sell it.
Devious your temps look above average (ie better than average, not too high)
stock volts on water isn't it?Quote:
Originally Posted by Repoman
Today got another 0610 -it looks even better :)
http://img268.imageshack.us/img268/1...131v3hx.th.jpg
Soooo lucky! :)
I got them both off ebay in the last couple of weeks. One of them was on buy it now for a few days and no one touched it, I think the buyer put people off saying it needed 1.42v to get to 2.8, and he showed a picture with it at 55Deg, I gambled on him having poor cooling and I think I was right :)
Managed to get a suicide at 3160mhz :woot:
http://valid.x86-secret.com/show_oc?id=92367
Voltage: 1.475x110% = 1.6225v
MemDiv: 140 = 243mhz 2-2-2-5 1T 3.4v
I agree, these chips need a good cooling , they get very hot .
And yes , I ve seen a couple of them on eBay as well.
And I ve seen them available for , I think , 2-3 hours at Flickerdown
:D :D - and then -"stay tuned " - a very nice shop :D
need to run 2 pi'sQuote:
Originally Posted by famich
My CPU seems above average..
http://img278.imageshack.us/img278/3370/38qr.th.jpg
nice clocks in this thread, people are likin the 0610s and 0608s. Weird how we haven't seen anything new for a WHILE, 0608 are like a month old, where's the new stuff! I saw FX60 posted with 0620! I'll bet they keep going with teh bugged memory controllers, which means 3 Ghz for us.
Also if you've got 3 Ghz dual core... put it to use! Run rosetta :D
http://www.xtremesystems.org/forums/...play.php?f=193
Team Xtremesystems needs every helping hand ;)
Also a good burn in tool, i run it 24/7 while burning in processors, won't crash or fail like prime. Also the loaded temps help the paste set.
/shameless promotion
here are the first results from my CCBWE 0609FPAW:
http://img386.imageshack.us/img386/2...145v5cv.th.jpg
Will try to lower volts, heat is killing me.
Question: will this chip run 3Ghz 24/7 under Mach II GT? Is it coldbugged?
i'm also pretty surprised we haven't seen any new steppings since the 0610. we are still seeing 0551's coming out of some shops
i think i got one without a cold bug :D
ccbwe 0602 bpmw
ihs off.
idle at 3.2ghz at -2*c
http://valid.x86-secret.com/show_oc.php?id=92379
