AE5 Water Block Questions
I have had my water block on and off 2 or 3 times. Mine initially had the plastic screws that bottomed out. It took me a few times, on and off, to get it fixed and now I took it apart again. The thermal tape is not in real good shape anymore. What can i use to replace it? Also, how tight to you tighten the 3 screws. I replaced the plastic ones with metal and it is quite easy to put stress on the PCB. The water block certainly does not fit on the four little chips very well. You can see it starting to bow when you tighten the end water block screws. It also bows if you tighten up the end brackets too tight.
Thanks,
John
