Any new and exciting bios ?
I have a question.
I have been overclocking a 2600K on a GA-Z68X-B3, and I can get it to run fairly reliably @ 4800, a little warm, mid to high 70 C, under a H70, and I feel just a few too many volts (1.44+) under heavy load.
BUT, say, the next day when I turn it back on, it can take many times to post & boot into windows, meaning, it will just start proceeding's, then shutdown momentarily, and try again, and again, but if I clock it "down" to say 4600, it's fine.
I guess this means it needs a bit more vcore or vtt.....what is safe ???
Any suggestions more than welcome. :shrug:
Cheers
id be backing off to 4.6 man and using less volts, doubt you will see any difference in those 200Mhz
Give it 1.360v at 4.5Ghz and call it a day.
on this far, anyone know ?
which BIOS version don't HAVE Vdrops ?
If we disable the thermal monitor option under bios would this mean that the voltage+multiplier will not drop during prochot status?
F5C OUT UD4-B3
http://forums.tweaktown.com/gigabyte...beta-bios.html
Whats new with F5C?
I would recommend not using F5C for the moment. The memory dividers are not correct and do not operate as they should. A setting of 1600 results in 1333MHz actual speed, 1866 => 1600, etc...
The problems have been reported and we should see another update soon.
Guys with Z68X-UD4-B3 board,can you check new Beta BIOS F8e and let me know.
Thanks.
Edit:
So far it's OK.No more memory multi bug.
any link F5C ?
I love this MOBO UD4 Powa!
http://www.ploader.net/files/f09504a...b749dde4a8.jpg
What can fix F5 bios? any new feature?
thx, agrhh mem bugs.........
DID anyone realize that's F5B has vcore bugs ( i'll call it ) when use C1e ?
when i turn on PC, with any setting C1e Enable and v core < 1.35v, Then Vcore will START 1.35v( but the speed still with my setting )
it's happend only FIRST turn on PC, not for restart pc
ex :
my setting : 1.26v @ 4.5 GH
vcore bugs : FIRST START will 1.35v @ 4.5 GH ( Vcore bug 1.35v )
( SORRY 4 MY BAD ENGLISH ! )
Vcore 1.26 was set by SVID or DVID?
@ ^ = DVID ( -0.100 v )
MULTI = 45 X
http://img14.imageshack.us/img14/221...1107191038.jpg
GA-Z68X-UD4-B3 - F8f
GA-Z68XP-UD4 - F3d
GA-P67A-UD4-B3 - F5d
Note:
Please note that this beta BIOS is still under testing and not approved by GBT standard test procedure .
I have UD4 -B3 with f4 bios...can somebody tell me if any other bios have LLC control, because only have enabled - disabled...what is the best bios for this mobo? thanks for reply.
F5D work great here...
wow -0.100 offset at 4.5Ghz, while mine needs +0.040 hahah!
