Can you explain why you proclaim lower to be better? This seems like an assumption on your part.
Skinnee, I am sure that the above question echoes among many other users.
May I suggest that you superimpose the PQ curves of the 350/355 and 655 on your graph? This would give users an accurate idea as to the flow performance enveloppe. You could do this relatively painlessly with photoshop. If you are short of time, and with your permission, We'll be happy to do this for you.
This is why I am looking at buying a 2000v+ bbu b/c I know that in the future I am going to need 1500W+ support anyways. Now if only it was not 120lbs...
Good to know the temps for the triple sli, I bet you get some great scores and fps on that beast!
Yeah, system flow rate is one of those topics that comes up continually, and I have loop flow rate numbers the data table for each block. Every block stayed above the 1GPM mark, which for me is the low side of where I personally aim to keep flow rates.
Yeah, I'll get another chart with 355 and 655 PQ overlayed... but don't have 350 numbers. I'm on my laptop atm, and the Excel workbook just kills this machine with all of the linked workbooks.
I'm running 3 GTX470's and a GTX480 (so 4 Fermi's alltogether) off one PA120.3 temps top 55/60°C with ambient around 30°C
Thats 3 Aquagrafx and 1 EK block.
with Dynamic Head Pressure from the D5-S5 with EK V2 Top (Top Outlet) and the DDC3.2 with XSPC V3 top.
http://skinneelabs.com/assets/images...480_pdrop2.png
Where each gray pump curve meets each respective pressure drop curve, that will be your approximate flow rate for that water block and pump setup.
For example, where the DDC3.2 w/ XSPC V3 top curve meets the the EK FC480GTX curve, you get an approximate flow rate of 2.5GPM.
Also, the pumps can and will go past 2.3GPM with the appropriate pump top.
the DDC3.2 is 18w as well afaik, i think you're thinking of the 10w DDC3.1. I think the flow rate/pressure drop is just for the block itself...
I'm dying over here skinnee! I really need those results... I'm about to pull the trigger on a koolance block and need to know whether I'm better off buying a DD instead.
:up:
That would be just the block and pump. You're going to have additional restriction in your loop with a radiator, tubing and so on... but blocks are the most restrictive component in your loop.
For instance, The PQ chart shows the EK block at 2.5GPM with a D5-S5/EK V2 Top, but our loop flow rate for our test loop was 1.74GPM with radiator, tubing, and QDC's. Each component brings restriction to the loop.
Oh yeah, and we used a DDC3.2 for the test loop, not a D5. :)
so far . . .Danger Den FTW?
the flow shows flow....:D temps show temps..
The DDC 3.25 is actually 20w max according to Laing's specs, not 18w as the resellers list.
