Thanks, guys. Re the case getting dusty ... yep, it certainly will. This was just a test build ... ultimately the components will go into an HTPC case, and the Torture Rack will be used for testing. And, for those that don't know it, I'm a gal - so if you were scratching your head at the baby blue theme, I hope that helps some ;)
And, after doing some more reading, I'm running Vista x64 right now, so maybe 3.6GHz 24/7 isn't all that bad. I'm very impressed with the performance I'm getting with this AMD system - love the fact that it generates far less heat than my i7 setup.
