I asked him and he said he had used windows 7 and vista. First impression was winxp 32bit (because CB10 ran as 32bit version).
He said he had to use vista to access the full 4GB so windows 7 must have been 32bit.
bro..u misunderstand me:D
the reason i swap to vista because i cant install overdrive in windows 7 ultimate
i can bench at 4ghz but not booting into windows, so wat i did is boot at 3.9ghz and push little more with AOD
all OS are 32bits;)
Edited:
and yeah,mem are not optimized
So your screenshot with XP GUI is Windows 7?
i have already said this myself a few times but its not gonna happen. even if you remove the few that are starting all this more will come and amd users will most likely post info about it as well. all you can do is just not respond to the info being posted.
yes i know that it is pointless to compare phenom I against phenom II but its the only thing you can do without starting a fight. it doesn't mean much comparing the two but it will show us what can be done that couldn't be done before. and since there are no official benchmarks out yet and it hasn't even been released you can't compare it against the intel cpus it will be competing against. why? because it will start fights that can't be ended cause there is no definite proof. as much as i think phenom II will be successful i can't prove it yet and no one else can disprove it.
@ lo squartatore sigh you are acting pretty immature right now when people are just trying to point out obvious facts. i think it would be in the best interests of you and others to just stop posting in the amd forum unless you can actually say something meaningful. and you keep disproving all information people are posting. saying that its fake, or not possible when you yourself can't prove that in anyway. plus your sig is just halirious. do you know what a quote is? a quote is when you repeat something that someone else said. when was the last time people here talked in italian so you can quote them?
you can use overdrive in win7!
Its easy. Grab it from another install!
(not to be rude or anything, havnt you done enough transitions to beta os's to know you have to do this alot ?. )
My od in win7!
Is the ability of Phenom II to oc NB beyond 2600mhz the difference maker in games when compared to other processors? Is this why the Dragon platform solution has the "potential" to best any other combo?
Or did my wife slip something in my coffee this morning? :shrug:
NB > 2600 is rare but certainly possible even with a Phenom I and the right tweaks. The HT Link has more influence over CPU video processing than the NB by itself but the NB does determine the total possible I/O of the CPU.
I didn't really get the rest of the question - I guess I'm dense today ... :brick:
I think so. But it's a combination of high northbride and hypertransport speeds that lead to an increase in performance.
And I believe the northbridge and hypertransport is why phenom users claim smoother gameplay.
It has been postulated in XS that the integration of cpu, memory, chipset, video card, and drivers results in a synergy producing superior performance. This is the AMD fusion marketing position. After the AMD event in Boston, some peeps reported Phenom II beat an i7 965 in a Crysis demo.
We don't know about that yet, hasn't been any details on if that'll make a difference and I don't see how it could really.
The clue was in the GPU-Z window.. ;)
More Phenom II benchies from http://www.hardforum.com/showthread.php?t=1376983 :)
nice i guess he did get it although it appears like an old one. i just hope i can get mine soon.
http://i42.tinypic.com/33wa4h4.jpg
Thats really bad lol
C2Q @ 4ghz can hit 6k cpu score.
The phenom2 at 4ghz should do around 5400 - 5500 I think.
This shows the CPU scores around 4483
http://www.breakthelimit.net/coolice...stock/3d06.PNG
and this shows 4091 and they ran the bench at the same resolution??
OK SEEN THE DIFFERENCE - The new screen is an ES where as the 4483 is a retail one also one is Vista and the other one is XP.
anyone know what the stock voltage is? cause i keep seeing pretty high numbers for voltage when its at 3ghz.
you cannot do like comparisons when they are not "like". I have not seen a 1066mhz ram with decent timings, etc. Until we see a decent review that compares systems with like compontents (besides board and CPU) can you judge a "like" comparison.
Ya it is a bit i seen most 3Ghz PhII's at 1.352 but this one was at 1.368 i think...!!!
