Thanx a lot Grn. Helpfull as always. U just use additional NB cooling? Rest heatpipe is stock?
Yes I left the heatpipe and SB alone totally stock.
Removed the Asus NB heatsink and replaced it with my MCW30 and AS ceramique paste. Thats all I have done to the board so far and I cannot complain any. Tweaking my E8600 now, r..e..a..ching for a stable 5.0GHz, but not sure if its going to happen, like my quad better anyways:D
this board is great my Maximus X38 will be back from RMA this week so looking forward to some head to head comparison.
I still cant decide between MFII+ddr2 or Rampage extreme+ddr3 tbh, both seems fine. But this is out of topic anyway. Just wanted to share my thought. Anyway, thanx Grn, again.
Anybody know what waterblock the southbridge setup takes, im gonna assume that those other mosfets/stuff to the left need cooled, same with the mosfets/stuff to the left of the northbridge??
Come on lets see some clocks:D
I would like to see your setup for 4.0GHz when you get there if you dont mind.
Took me 4ever to get my chip stable at 4.0 and I still think the volts are kinda high altho temps are very decent.
GTL's are probaly set wrong and the NB / CPU clock skew is new to me comming from a Maximus X38 and there is little reference to it.
Hey Grn
any suggestions for a try to reach 4GHz?
Just up dated to bios 1307 from 802. Could not get my fsb over 500. But with new bios so far at 540 and cpu running 7.5 multi.
anyone please can help me to get 500 or more fsb, please need guide
This guy only posted twice so I doubt I'll get a reply from him, but has anyone experienced this crashing during 3D? I was hoping to get this board but it is bad that 2 reviewers had this issue and another couple of people also (X2beach is second user with this issue he RMA'd and got a P5Q and the issues were gone - means the motherboard was dodgey). If anyone can give me some info on this issue I'd appreciate it.
It was my understanding that OCZ Reapers were not compatible with this mobo, bios 802 added some memory compatability but unsure if that kit was part of it.
I run a 3870X2, I play WOW, Bioshock, Alone in the Dark, Gears of War and Lost Planet, none crash or have ever crashed.
Granted I havent had this board very long but I honestly have nothing bad to say so far.
About to test new bios 1307, need to break 20k on 3dmark:D
Cheers mate, I think it can't be a common issue, and is most likely a compatibility issue of some kind. I think I'll get one still, if it gives me any issues I can return it and get another I suppose. I have had major dramas with my P5Q-D so I hope to this time get a good board.
I have seen bios 604 recommended for stability and high FSB clocking, but also 802 seems to be popular. I have TeamXtreem 1066 D9 based ram, and I have Cellshocks on the way, are you aware of any incompatibility issues between them and the M2F?
Good to hear, I know what I'm doing so I shouldn't have any issues setting the board up, I'm actually looking forward to having so many options at my disposal. I'm going to order it now, so I should have it by the end of this week latest. Here's hoping it's a good example like you guys have :D
I have 2 kits of TeamXtreem that do 1333+ (Cellshocks coming too) so I hope this board can clock memory high, I intend to have some fun with it.
We will be waiting for your results :D
is 40 celcuis idle high for the nb and sb temperature? and last night i turned off my computer as usual and when i wake up today and turn it on. the computer turns on. lcd poster looks right. but i get nothing on the screen. i ended having to turn off my psu from the back. turn it back on and then i would have image on my monitor. ill take whatever advice i can get. this isnt the first that its happened. i also cant come back from sleep/hibernate. like it just wont wake up. wierd
Hi,
I believe OCZ reapers are not compatible with that board at Bios 0901.
I switched back my Mushkins(2x2gb Redline 1000mhz). Then everything
is stable for now.
Meanwhile, i cant lower NB and SB temp under 50C as my room temp is about 30 these days. I pulled of all heat sink, and applied Arctic Silver 5 on both SB and NB. then squeezed all screws tightly. I just can decrease the temps from 65s to 50C.
Maybe i should back to watercooling solution for NB and SB.
heres a little comparison between the Maximus formula and the Maximus II.
notice the Vcore difference and the formula was weak on the q9550 being that max stable was flaky at best just over 3.7 Ghz.
the Maximus II takes this chip 500 FSB but I'm still playing at the 4Ghz mark for now. :D
http://i201.photobucket.com/albums/a...8_19-28-23.png
http://i201.photobucket.com/albums/a...8_11-16-25.png
