does anyone own an AGP board that has a processor that would not CPU limit this card? i dont know of anyone that does
are multi gpu fixes really needed with 3870 in crossfire and which ones would you recomend.On vista 64
Yes of course.
Must have essential fixes:
KB938194
KB938979
KB940105
KB941649
only for users of SLI/Crossfire:
KB936710
KB945149
To see which updates you have/don't have yet: View the history in Windows Update in Control Panel, or go to Installed Updates:
Start button > Control Panel > Programs, under Programs and Features, click "View installed updates".
Thanks man:)
Is there a way to set fanspeed for CF3870on vista 64 rivatuner sets the fan back to default on every reboot.
Check the box that says "apply fan settings at startup"
Im not sure about setting it for crossfire, i think you can. But im not sure, someone here with CF should be able to explain it.
Im on vista 64bit, i have no problem setting the fan speed..
Single HD 3870 @ 830/1150
X2 5600+ @ 3.0Ghz
4Gb Corsair XMS2
Vista Home Premium 64bit
Settings: High / DX9 / 1280x1024 / No AA / 32bit
http://i151.photobucket.com/albums/s...nchmarkDX9.jpg
Settings: High / DX10 / 1280x1024 / No AA / 32bit
http://i151.photobucket.com/albums/s...kDX10lwres.jpg
Settings: High / DX10 / 1680x1050 / No AA / 32bit
http://i151.photobucket.com/albums/s...X10highres.jpg
Ill try and get some 64bit ones later, and see if there is a difference
What driver cleaner do you guys use when removing drivers of a 3870?
Just the ATI uninstall method. Works fine.
http://home.planet.nl/~dekk0819/down...-addremove.jpg
I have this card since December and right away installed Cat 7.12 and no reason to uninstall it yet. Why? Why uninstall 7.12? It's the latest. What problems do you have then?
With regard to your problem, came across this link on another page here at XS and believe it will be of help. Good luck!
http://forums.amd.com/game/messagevi...&enterthread=y
Rob
Doesn't that ATI forum have a :banana::banana::banana::banana: interface with that MUCH too narrow centered frame with scrollbar at the bottom of the frame instead of the bottom of the browser! :shakes: :rolleyes: Ever since that forum exists it is that way. Btw, on day one i registered, but never received a confirmation email to validate the account, so i could never use it. New account impossible with the same email address. And i can't complain about this without first logging in. :rolleyes:
First month it really didn't look very useful forum anyway, i decided to never bother about it. :shrug:
MY site? :confused:
What makes you think i'd shoot you for that, Rob?
My point is i wanted to read that post but it is só stretched by the images that it is IMPOSSIBLE to read the text without scrolling down to the frame's scrollbar every single time after reading a sentence to the end, which i gave up after two or three. :rofl:
Not your fault, Rob. :doh:
someone tryed to run DIRT on a HD3850 256mb? I'm getting a really poor performance at 800x600 medium!?
I noticed with the new 7.12 drivers, DiRT doesn't work right. It does with the 7.11's though.
With the 7.12 drivers, the cards won't clock up to 3d mode. They stay in 2d. Atleast thats what happens to me.
thx, I fix that overclocking the card, so the clock stay at 750mhz in 2d and 3d, I played the game and when you are alone the framerate is good, in the races with more cars the framerate get a lot lower...
is normal the gpu use around 50% during the game?
http://img87.imageshack.us/img87/4792/gpuuseae7.jpg
That happens when i set the clocks like that too. Try the new 8.1 drivers, those should fix it. They were just released :up:
with the new driver the game runs better.. but still, I think this is a bit strange, the first part I was playing rally, with very good framerates (only one car on the screen), the second part when the gpu use is lower I was playing the races with more cars on the screen and I really can feel the framerate going down... still, is a lot better, but I don know, maybe my cpu is limiting? (brisbane @ 2600mhz), I'm playing at 1024x768 custom (high with AA disable)
http://img242.imageshack.us/img242/1775/gpuusegm5.jpg
