Who is the zealots, you don't even click on shintai link. So as you're too lazy.
AMD benchmark configuration information for such kind of comparison:
# 2 Xeon 5355 processors in FSC Primergy RX300 S3, 16GB memory, 73GB SAS disk drive,
Microsoft Windows®Server 2003 x64 Enterprise http://www.spec.org/cpu2006/results/...219-00524.html
# 2 AMD Opteron™ processors Model 2222 SE in Tyan Thunder n4250QE motherboard, 8GB memory, 80GB SATA disk drive,
SuSE Linux® Enterprise Server 9 SP3 http://www.spec.org/cpu2006/results/...319-00684.html
# 2 Xeon processors 5160 in FSC PRIMERGY TX300 S3, 16GB memory, 73GB SAS disk drive,
Windows® 2003 Server Enterprise Edition SP1 http://www.spec.org/cpu2006/results/...122-00249.html
64-Bit SUSE LINUX® Enterprise Server 10 http://www.spec.org/cpu2006/results/...219-00523.html
SuSE Linux Enterprise Server 9 SP3 http://www.spec.org/cpu2006/results/...319-00685.html
64-bit SUSE Linux Enterprise Server 10
And again in the barcelona simulated comparison, if you take about 3s to read the footnote:
http://multicore.amd.com/GetFile.asp...trate_040207v2
you read:
"competitive benchmark results stated above reflect results published on
www.spec.org as of april 16. 2007. The comparison presented above is based on the best performing blabla... "
Best performing... Nowhere best performing using this and that blabla, just best performing, they don't care of os or compiler, they only take the "best performing"
