does that bolt on to a drill or is it some sort of hand tool?
omg :shocked: :shocked: :shocked: :shocked:
Very nice build, RAID, I'm impressed. It looks like a machine from the future :)
Its' a hand tool. You need a 3/8" pilot hole to get the center pin through. Once the punch is assembled with the flange on one side of the material, and the 'bite' side on the other, the center pin is tightened with a ratchet until it pops a slug out of the material.
Raid, that is a thing of beauty. very simple, but very eye catching.
RAID, that is just awesome! :up: :up:
http://www.abload.de/img/imgp3495v5o.jpg
Wow RAID!!!
That looks fr1k1n AWESOME!!! :shocked:
I envy you... you, your build and your, err, camera!!! :D
RAID your bench setup looks sweet m8! That DD table isn't bad at all if you look from your perspective. nice man.
funkflix, your pc looks like mine a while ago, you already know what I think of your setup man ;) ass whipping!
Then my parts from Petras have arrived! :woot: :D
@raid
WTF!!! I Thought its a Featured PC in one of the Exotic Computers ever made like Vadim's...
@dnb
kindly check my prob here... and the rest of you here... Will definitely Appreciate your Advices regarding my Watercooling LEAK!!!
http://www.xtremesystems.org/forums/...d.php?t=179442
Thanks...
raid that is sick mate!!!!!
thanks guys, i really appreciate the comments.
to address a couple of the questions, i'm using the Danger Den Torture Rack which is more of a test bench than a case. i really like it because of how versatile it is and did not have to drill one hole to mount both loops. plus the tubing runs are very short while the draining, filling and bleeding of the system is very easy thanks to the ek multi option reservoirs.
i'm using the yate loon D12SL-12 fans from petra's.
and i won't be moving this case around at all so LAN parties are out of the question.
again, thanks for the comments. smee, hurry up and get your parts!
Wow, that system is gorgeous RAID. Truly a work of art; I really like all the blue.
RAID, that's definitely the best DD torture rack I've ever see. Very well executed. :up: :clap: :yepp:
@ Raid, are these the fans you are using in your rig?
http://www.petrastechshop.com/12yalod1blle.html
god dam if they are they are HEAPS cheap!!!!!!!!!!!!! :)
Also what is your conclusion on these fans? they any good?
thanks man
Here's my SkullTrail upgrade to the Soldam.
http://img352.imageshack.us/img352/1760/clear254qg0.jpg
http://img502.imageshack.us/img502/3812/clear255km0.jpg
http://img219.imageshack.us/img219/9175/clear256oe7.jpg
http://img412.imageshack.us/img412/7061/clear258gc1.jpg
http://img147.imageshack.us/img147/6323/clear263av3.jpg
http://img352.imageshack.us/img352/6745/clear265gq1.jpg
http://img404.imageshack.us/img404/8619/clear266et9.jpg
http://img212.imageshack.us/img212/784/clear274ir2.jpg
http://img151.imageshack.us/img151/7141/clear275ga4.jpg
http://img519.imageshack.us/img519/5569/clear276yt8.jpg
http://img116.imageshack.us/img116/5959/clear292ve5.jpg
http://img337.imageshack.us/img337/9577/clear293wn2.jpg
damn cyber!!!
thats awesome
Amazing job CyberDruid :up: What 3DMark06 do you get with that? Are the CPUs in series or parallel?
nice one! how are you guys able to get the skulltrail mobos?
Also, only 1 3870x2?
New here, wanted to share some photo's of my pride and joy!
