Arnt people with the Giga Byte NF boards haveing the same type problems with Winnies ? Seems like I read in some thread that they were.Quote:
which bios do u guys run ??
1.36beta, worked great :D
look at pifast link ;)
What are the max VCores for the new BIOSes (1.41mod, 1.5x, 1.51)?!
I am kinda "stuck" @ 1.55V +10% (1.700V) with my 1.41 Bios.
Cant you make it 1.55 + 18%?Quote:
Originally Posted by pk0r
max Vcore for every bios, except 1.36, is 1.7V, if i remember right.Quote:
Only the 1.36 bios has a working 1.55V+18% (=1,829V)
you can find the changelogs for the biosses here
Quick question what's MSI's official warranty stance of boards returned/rma'd with black plate glue having been pryed off ???
Actually, the back plate is "double sided sticky taped" on... so when you pull off the backplate, keep it in a safe place and put it back on there if you have to return/rma. shouldn't be an issue at all... the tape comes off with the back plate and is reusable... :)Quote:
Originally Posted by eva2000
I put mine in a small poly bag and let the bag stick to it, otherwise it'll get stuck to some paper or something :eek:
Have to replace thermal interface on this board for sure :)
http://img85.exs.cx/img85/3743/nbnogrease02s5gp.jpg
Shaotai
Welcome to the sickness. :banana:
There's a chipset voltage? :?Quote:
Originally Posted by IvanAndreevich
viccyran
No, there isn't. I was being stupid in the middle of the night.
I think I was trying to say whether you've tried a VDD mod on it or not.
i seen what mosfets that should have heatsinks on them but where can i buy some that will fit.
odb
Any BGA ramsinks for videocards should fit ;)
Am i the only one that cant get agp cards to work with this board :O ?
Other than that it works pretty good accually :)
Murmlos
You got a fup'ed board. RMA/replace it ;)
wanted to update, I've been keeping my FX at stock for now, I've been using the 1.51 bios and I beleive its most likely my cpu maxing out but I'd like to know if anyone else is using an fx53 here, also here is my cpu spec:
http://intenseghetto.com/o/albums/mods/amd/dsc02108.jpg
uniacid,
it looks like more people have a similar cpu
http://xtremesystems.org/forums/showthread.php?t=46810
What is the BEST bios for achieving HIGH HTT? 300x3 is not stable.
Hmm, 1000 is standard, why is it not stable? Try the 1.3b6!
I just received and tested my 0412, superb!!
Finally no more memory errors @ 260 with my BH-5 :thumbsup:
Now if I can bench 10x280... :D
sigh if only I could go above 2.6 :/
2 out of 3 boards of mine are FUBARed,
1st board had 2 smd resistors fall off from near the cpu.
That happened while changing CPU's. I did not put any pressure on those smd resistors. They were so badly soldered on that as soon as they were touched by accident, they fell off.
2nd board has 3 faulty dimm slots.
Using a 3200+ 0441, I tested using only 1 dimm & only slot 1 works. As soon as I place the same dimm in any of the other slots, my rig beeps its head off. :mad:.
Funny thing is I had memtest running 20 hours+ @ 250MHz 1:1 (slots 1&2) & booster in slot4 & it ran fine. WTF??
Thinking it was a 90nm problem, I put in my 3500+ NewCastle & straight away got those damn beeps...
MSI have a good board if it's been through their Quality Testing Procedure :rolleyes:. The only good board I have is the one I'm typing this on...
Still wondering why dual channel runs memtest fine but single channel beeps it's head off. Also, although dual channel ran fine, as soon as winxp loads up; it's only a matter of minutes before I get the infamous BSOD or my rig just freezes on me...
Oh well, looks like MSI are gonna be getting 2 of their "Platinum" Editions back :rolleyes:.
Minh
GravediggA
I was running 1.36b when I said it's not stable. I am trying 1.37mod now.
How can u tell if your motherboard is having a problem with the powersupply? the reason i say this is because i think mine does. It detects certain things on the motherboard everytime i reboot, and if i change around the power connectors to the hardware it will detect new items...
also has anyone had problems with this power supply?
X-Connect 500W and the neo i plan to get this if it is indeed my psu.
