Phatboy,or anybody else, where are you placing some of your temp sensors and how are you attaching them?
Thanks,
John
Thanks,
John
I have air in/ air out on the rad, case temp, water out of res, water out of rad, water out of GPU, water out of CPU and water out NB/MOSFET...
Don't understand the "how are you attaching them" part though...
I am here: http://maps.google.com/maps?ll=50.836360,-0.138677
I guys, I thought I had all my answers but can't seem to find this one. I am going to wire the relay into the power switch for shutting down the PC on an alatm. I also have the USB hooked up. What is the stand by for on the attached picture?
Attachment 119183
Thank you,
John
Guys i have problem. When i plug in 8 fans: Phobya G-Silent 14 1100rpm Red LED, i have very high temp on Fan power amplifier - that is 95+ degrees. This is how that looks:
http://www.abload.de/img/overheat2kpl.png
Connection looks like this:
Canal 1 - 2 fans
Canal 2 - 3 fans
Canal 3 - 3 fans
Technical specifications of fan:
Dimensions: 140 x 140 x 25mm
Colour: Transparent frame, blue fan blades and blue LEDs
Weight: 140g
Nominal voltage: 12V
Starting voltage: 7V
Current draw: 0.17A
Nominal speed: 1100rpm (+/-10%)
Airflow: 90m³/h / 53 CFM
Noise level: 24 dB(A)
MTBF (25°C): 50.000hrs
Connector: 3-Pin
Maximum static pressure: 1.61 mm H2O
Special features: 4 integrated red LEDs for lighting
What can be wrong ?
Has anyone tried using Aquasuite 2010 B6 yet? I tried to update my firmware to 1014 and it just keeps saying "Error!, reflash firmware" and the software no longer communicates with my AE5.
Look up - i have b6 and no problem with update ae5 to 1014
At the moment it is not clear how we will offer that. Of course people with problems should get it for almost free but this also brings us to the problem that also people without problems want to have it. It's new, it's shiny - I must own it even if I have no advantages at all :D
Does the red LED at the back work? No matter if it blinks or stay on permanently: in this case you have a chance to recover it. Remove all unnecessary connections with exception of the power. When turned off, place jumpers on the temperature sensors 5 to 8. Start the device afterwards and you should come up with a new screen which tells you that your device is in recovery mode now. Turn it off, remove the jumpers, attach USB and run the aquasuite. You should be now able to flash the firmware again.
Maybe you should try a reset before flashing. Follow the instructions above but only place a jumper on temperature sensor 8!
Shoggy, here is what I got.
The red light on the back was on. Also, everything else seemed to work except the LCD. I tried all 4 fan channels and a couple temp sensors and they were ok. Also, the Aquabus seemed to see the extras from my PA2's.
I powered off the PC
I put jumpers on temp sensors 5, 6, 7 and 8 on the AE5
I pluged the power into the AE5
I turned on the PC
I left it on for about 5 minutes but never got any text on the LCD about recovey mode
I removed the jumpers from temp sensors 5, 6, 7 and 8 on the AE5
I hooked up the USB cable to the AE5
I powered back on the PC
I launched Aquasuite 2012 beta 6 and flashed the bios (1014 I think)
The AE5 immediately beeped about three times, quite loudly. I had no LCD
I powered on the PC
I am able to see all the sections in the software but still have nothing on the LCD
What do you suggest I try now?
Thank you,
John
OK, the controller is working correctly so I guess your display is damaged when you don't see anything. It is only plugged to the main controller so you could try to remove it and plug it back again. Maybe some bad contact.
yepper. Tried that twice.
Errr, tried what? Firmware flash or plugging the display out and in?
Plugging and unplugging the LCD. Here is where I am at not. the red light on the read is on solid. Also, as soon as i plug in the USB connection, even with the PC turned off, ithe AE5 beeps a few times and the backlight comes on and the three touch buttons light up solid red. When I power on the PC it remains the same way.
John
Check your e-mails.
I have a quick question for aquero 5 owners or possibly Shoggy if he sees this, is it possible to configure the unit to keep the pump and fans running off the aquaero 5 after the pc has powered down using the new software in conjunction with the relay plug and the atx extension you sell? If it isnt would it be feasible to implement in the future?
That is not possible and also will never be because when your PC is turned off you don't have any 12V supply.
Also don't believe in that idiotic marketing that you would have any advantages by using this feature. When there PC is off the temperatures fall down immediately and there is absolutely not reason to cool that any further.
There is definitely a benefit. In a OC environment there is a lot of system restarting when testing settings. any board i have had recently shuts down the power when changing settings as well.
So by keeping it running you save on pump and fan motor wear and tear. I myself run a separate power supply to my water cooling for this very reason.
Not saying this is a feasible option for this device. Just saying there is a definite benefit and want for this.
Sent from my GT-I9100M using Tapatalk
When you connect the relay parallel to the power button of your case you will not need the standby cable.
You would only need it when you want to use the ATX break adapter and when USB (which normally powers your aquaero when the PC is turned off) is not connected. In this case you would not be able to turn on the PC anymore when it has been turned off by the relay because when it breaks the power, also the main power of the aquaero gets interrupted and the relay is not able to switch back in its normal position. By using the standby power the relay is able to switch back so you can turn on your PC again.
Shoggy,
Nice explanation. Thank you. Next question(s):
A PC power switch is a normally open switch, correct ?
When wiring the relay into the switch I use pins 1 and 3 on the relay plug. Does the order matter (positive or negative)?
Can I just wire them directly to the switch (along with the wires going to the mainboard) as opposed to splicing them into the middle somewhere?
Thanks,
John
Yes, the power button is a open connection so only when it is closed something will happen (power on/off, standby etc.).
The order does not matter since there is no positive or negative. Image it the following way: the negative line is already on the mainboard while the positive line is connected to the button with two ends. So by pressing the button you will close this line and something will happen. Of course in this case it does not matter how you connect it since this wire has no specific polarity.
You can connect them where you like: at the button, at the mainboard or somewhere in between ;) It will always be the same when the connection is closed by the button or the relay.
