Those guys are doing something wrong. There are so many settings on this board . . .
I was much more impressed with memtest86+ v2.01. This is the one from
http://www.memtest.org/. The one from memtest.com is memtest86 v3.4 (notice there is no plus sign). memtest86 v3.4 had my CPU listed as pentiumIII. That shows you when the last time they updated it was.
Anyway. I figured out my problem. It was from a Saitek back lit keyboard being plugged into a Dtek USB hub :shrug:. The problem is reproducible. I need to do some more testing, but it doesn't seem to have anything to do with the Rampage or the RAM or the E8400 (so sad, I was hoping for a chance to RMA cause 3.9Ghz at 1.4v sucks).
This FAQ was very helpful in figuring out my problem, especially the part about getting rid of all unecessary components. You'd think common sense would have told me to do this, but it didn't.
http://forum.x86-secret.com/forumdisplay.php?f=14 If you have any questions about memtest86+, this is the place to go. The guys seem very dedicated to solving any problems that may occur.
The good things about this whole ordeal is that I really got to learn about the settings on the board. "DRAM controller reference voltage" still alludes me as well as the GTL settings. I haven't messed with them yet.
On a side note- I realized that the power connector for the CPU has a cap over half of it. I originally had a four pin PSU connector plugged into it. Tonight, I took the cap off and plugged in the eight pin connector. The difference is two more yellow (+12v) wires. Could this make a difference in anything? Is this for quad cores maybe? Maybe I can get some more out of my E8400.
